Author Topic: Smoke billowing out of intake.  (Read 4358 times)
Re: Smoke billowing out of intake.
« Reply #15 on: March 25, 2019, 05:02:28 AM »
A lot of blow lamp start or hot bulb engines can run backwards quite easily even the Lanz Bulldog tractors can do this if you dont bounce the flywheel off compression at the right time. Then you get 3 reverse and one forward gear.
« Reply #16 on: March 25, 2019, 06:28:42 AM »
And it does clean the wasps out of the intake pipes !
