Author Topic: For those near Brisvegas ( Bob) potential cheap ST2  (Read 2894 times)
guest22972
« on: February 12, 2019, 10:37:45 AM »
For those in the northerly, sunny part of oz, I hate you.  Oh, and there is a supposely running ST2 being auctioned which is at $1 atm.
https://www.ebay.com.au/itm/LISTER-DIESEL-ENGINE-ST2-2-CYLINDER-14-6-20HP-with-Operators-Handbook/153365681662?hash=item23b54e95fe:g:6n8AAOSwkRdcWV0s:rk:32:pf:0
Could be a real bargain. Usualy these things go for stupid money here. nice to see somone that will let the market decide what it's worth... which will be interesting to see.
Re: For those near Brisvegas ( Bob) potential cheap ST2
« Reply #1 on: February 12, 2019, 11:40:45 PM »
Love you too!  :laugh: I`m not in the market for a second ST2 but it will be interesting to see what it goes for.  I spent around $1000 on completely rebuilding mine, re-bored cylinders, new pistons, bearings, bushes and etc. Total cost for the project including the generator shed and wiring about $3000.
In my opinion this would be a very sound investment for anyone with the time and skills. It would happily drive a 7.5 KVA generator or a large water pump. A lot more economical and long lasting that a petrol generator, for not much more money.
Lets hope someone gives it a good home.
« Reply #2 on: February 12, 2019, 11:50:37 PM »
Hey Bob we have these engines - or some newer equivalent that looks pretty similar - as stand-alone units driving water pumps in remote locations.  They are bloody loud and they seem to vibrate a lot to my eye.  What's it like outside the shed with the door closed?  Cheers, Mike
« Reply #3 on: February 13, 2019, 12:45:33 AM »
Hi Mike, since these are air cooled sound proofing is an issue. My generator shed is far enough away from the house for this not to be a big problem, it has a concrete exhaust chamber buried in the ground which helps. I also made louvered doors for it, which also reduces the noise. I have never experienced any vibration problems but that might be because it has rubber mounts and is bolted down onto the 150 Ltr fuel tank. The picture will explain everything.
« Reply #4 on: February 13, 2019, 01:27:59 AM »
Great-looking installation, Bob
Our engines have been attached to belt-driven pumps & mounted on a sort of pallet about 2 metres in width
Because of the rubber mounting, vibration is concentrated in the motor and the standard controller, which sits atop a 40X40 pedestal, rattles around so much the it'll begin to fall to pieces in a few days (poor design).  We just sink a post into the ground nearby & mount it on that - problem solved
Apart from the occasional fuel solenoid or engine oil pressure sender failure - they have been boringly reliable
And, because they go out on farm, they are obviously designed to run for years without an oil change or servicing of any kind too . . .   I guess when the oil low-level circuit throws up its hands in despair, whoever gets called out to fix it, gives it a "birthday" and on it goes . . .
« Reply #5 on: February 13, 2019, 06:04:44 AM »
Very classy, working setup, Bob. Beautiful restoration work.
« Reply #6 on: February 13, 2019, 09:04:14 AM »
Hi Guys, I`m very glad I did this setup before my car accident and subsequent heart attack. I couldn`t begin to tackle a restoration like this now. My recommendation to anyone thinking of doing anything like this is: "do it now, tomorrow may be too late!"
Hi Glort, always difficult to find a compromise between maintaining a happy wife and satisfying your own proclivities, good luck with the drive.
« Reply #7 on: February 13, 2019, 11:14:54 AM »
Gen heads in Australia at a sensible price are about as common as rocking horse sh1t. A sensible fellow with a few bucks could make a small fortune importing them and supplying parts and expertise. If I was a young man I would be doing exactly that.  I would set up a web site offering generator heads and adapter plates. pulley wheels, vee belts and etc. I doubt you would get rich but I think you could make a very good living.
sirpedrosa
« Reply #8 on: February 14, 2019, 12:11:51 AM »
Hi Bob
You are indeed young, and your idea is crystal clear of an entrepreneur.
The picture is already made. Go ahead we are with you.
By order of firing up:
