Lister Engines > Lister Market Place (things for Sale)
For those near Brisvegas ( Bob) potential cheap ST2
guest22972:
For those in the northerly, sunny part of oz, I hate you. Oh, and there is a supposely running ST2 being auctioned which is at $1 atm.
https://www.ebay.com.au/itm/LISTER-DIESEL-ENGINE-ST2-2-CYLINDER-14-6-20HP-with-Operators-Handbook/153365681662?hash=item23b54e95fe:g:6n8AAOSwkRdcWV0s:rk:32:pf:0
Could be a real bargain. Usualy these things go for stupid money here. nice to see somone that will let the market decide what it's worth... which will be interesting to see.
ajaffa1:
Love you too! :laugh: I`m not in the market for a second ST2 but it will be interesting to see what it goes for. I spent around $1000 on completely rebuilding mine, re-bored cylinders, new pistons, bearings, bushes and etc. Total cost for the project including the generator shed and wiring about $3000.
In my opinion this would be a very sound investment for anyone with the time and skills. It would happily drive a 7.5 KVA generator or a large water pump. A lot more economical and long lasting that a petrol generator, for not much more money.
Lets hope someone gives it a good home.
mikenash:
Hey Bob we have these engines - or some newer equivalent that looks pretty similar - as stand-alone units driving water pumps in remote locations. They are bloody loud and they seem to vibrate a lot to my eye. What's it like outside the shed with the door closed? Cheers, Mike
ajaffa1:
Hi Mike, since these are air cooled sound proofing is an issue. My generator shed is far enough away from the house for this not to be a big problem, it has a concrete exhaust chamber buried in the ground which helps. I also made louvered doors for it, which also reduces the noise. I have never experienced any vibration problems but that might be because it has rubber mounts and is bolted down onto the 150 Ltr fuel tank. The picture will explain everything.
mikenash:
Great-looking installation, Bob
Our engines have been attached to belt-driven pumps & mounted on a sort of pallet about 2 metres in width
Because of the rubber mounting, vibration is concentrated in the motor and the standard controller, which sits atop a 40X40 pedestal, rattles around so much the it'll begin to fall to pieces in a few days (poor design). We just sink a post into the ground nearby & mount it on that - problem solved
Apart from the occasional fuel solenoid or engine oil pressure sender failure - they have been boringly reliable
And, because they go out on farm, they are obviously designed to run for years without an oil change or servicing of any kind too . . . I guess when the oil low-level circuit throws up its hands in despair, whoever gets called out to fix it, gives it a "birthday" and on it goes . . .
