Author Topic: Start-o-matic  (Read 2050 times)
Start-o-matic
« on: February 04, 2019, 05:59:37 PM »
https://www.trademe.co.nz/Browse/Listing.aspx?id=1938416060
I put a bid in on this - who knows?  Might be something in the boxes that is of use to someone as well
Re: Start-o-matic
« Reply #1 on: February 05, 2019, 04:00:21 AM »
Check out this one then
https://www.trademe.co.nz/Browse/Listing.aspx?id=1938636592
The optimist/dreamer/greedy farmer wants $4K for it
It has sat in a paddock a lot - but has the appearance of having done almost no work
he bought it in 1992 and is sure it was "new" then and that it was imported as "New Old Stock" from Argentina of all places.  it has the "Lister Dursley England" stuff but the little serial # plate is missing.
Sadly the case is full of water and there's no compression with the exhaust valve stuck open (the valve lifter was jammed "on") and the rack & linkages are seized.  When I turned up he was spraying INOX on the linkages and cranking it to see if it would go . . . .
He says he isn't inclined to take $500 for it
Then there's this bloke:
https://www.trademe.co.nz/Browse/Listing.aspx?id=1929971096
He wants $3200 for this unit & I predict he will be wanting it for some time yet . . .
So there you go
