Author Topic: Exhaust joints  (Read 4218 times)
Jordan
Exhaust joints
« on: January 28, 2019, 02:00:22 AM »
The exhaust system is made up of sections of pipe and a muffler.
They are slip fit to each other, with ends expanded where necessary so one pipe end fits into the other.
I find that there is unacceptable leakage at all joints when the engine is running.
I'd love to have a totally sealed system, without having to weld the various pipes/muffler to each other.
Could there be some solution?
Re: Exhaust joints
« Reply #1 on: January 28, 2019, 03:29:06 AM »
I had the same issue.  I used the highest temperature silicone I could find at the time- the copper doped high temp stuff, Permatex I think.  Took it apart and gooped the joints. That did the job.
Re: Exhaust joints
« Reply #2 on: January 28, 2019, 07:04:08 AM »
Hi Jordan, I have tried a few different methods depending on the size of the gap. Larger gaps I fill with fire cement, smaller gaps with high temp silicon. I have also had some success with exhaust repair bandages available from your local auto center. When using fire cement, please wear rubber gloves as it is very nasty stuff and will dissolve the skin on your hands. You need to let it dry out before firing it by running your engine.
Jordan
Re: Exhaust joints
« Reply #3 on: January 28, 2019, 07:44:47 AM »
Speaking of silicone, I wonder if the hoses that are made of this stuff and sold as "go fast" accessories for aftermarket turbocharged cars possibly suitable?
They'd need to cope with the change in size of a few millimeters as the jointed pipes' diameters vary.
I sent an enquiry to a supplier about this.
Re: Exhaust joints
« Reply #4 on: January 28, 2019, 08:15:13 AM »
Hi Jordan, I`ll be very interested to hear what they come back with.
dax021
Re: Exhaust joints
« Reply #5 on: January 28, 2019, 09:10:45 AM »
That's what I did.  The Cu silicone gasket sealer works perfectly and have had no leaks for more than 2 yrs.  You could also put an exhaust clamp around the joint and fasten tightly.  Unless your pipe is 3mm (1/8") wall thickness, this will crimp it on.
Jordan
Re: Exhaust joints
« Reply #6 on: January 30, 2019, 09:43:10 AM »
It's been a couple of days, and no word from the silicone hose suppliers.
Must have been too technical a question for a sales person.
I'll go with the Permatex Cu-silicone stuff in a tube.
Thanks folks.
vegoil
Re: Exhaust joints
« Reply #7 on: January 30, 2019, 01:13:08 PM »
Just to give an indication of temperature My CS 8/1 Runs about 220*C 6" from the manifold and 130*C 4 foot from the manifold. I bought a tube of exhaust sealant from a exhaust and tyre garage works good (no leaks). give them the size difference of the pipes and they will keep you rite.
John
« Last Edit: January 30, 2019, 04:56:08 PM by vegoil »
Re: Exhaust joints
« Reply #8 on: January 30, 2019, 02:56:22 PM »
There are aslo stainless steel band clamps that surround the joint and seal tighly. Used on large trucks so a truck parts place is where you look for them. A bit spendy but solid reliable fix.
Jordan
Re: Exhaust joints
« Reply #9 on: January 30, 2019, 10:54:05 PM »
I got a piece of silicone hose from a friend.
It has some textile insertion material in it.
I found it very resistant to both stretching and to being compressed down to a smaller ID.
So that's ruled out for my exhaust system, where it would need to cope with differing diameters at the joint.
Unless I can find some with the needed sizes built in, but I'm wasting too much time already...
« Last Edit: January 31, 2019, 12:58:53 AM by Jordan »
Jordan
Re: Exhaust joints
« Reply #10 on: February 08, 2019, 11:20:24 PM »
I assembled the slip joints with some Permatex copper/silicone that BruceM and others suggested.
Cleaned the surfaces with Acetone, put a bead on the inner surface, 2 beads an inch apart on the outer surface - boy, it's thick stuff, needed some squeezing out of the tube even with a 5mm hole in the nozzle. Then the joints were slipped together.
Left it overnight, started engine.
It's nice to breathe fresh air in the shed.
Re: Exhaust joints
« Reply #11 on: February 09, 2019, 04:14:17 PM »
My missus has silicone baking trays for flans and such like so it can take a fair bit of heat
Re: Exhaust joints
« Reply #12 on: March 01, 2019, 03:02:09 PM »
I used  the stretchy Silicone exhaust tape on my Listeroid exhaust joints and it works great to close off any tiny leaks.
The problem is at the first joint in my system is only 1 ft. from the cylinder head.
That joint reaches 500f under heavy load and it cooks the silicone.
Turns it from Red to Brown and starts to curl and peal off.
So be aware that the silicone tape has limits. Otherwise it's great stuff.
Re: Exhaust joints
« Reply #13 on: March 01, 2019, 03:11:04 PM »
......That joint reaches 500f under heavy load and it cooks the silicone.....
Wow, I barely see 320F with my IR thermometer.  That's a 6/1 loaded to about 2,800watts and a 195F coolant thermostat
There is high temp masonry silicone for fireplaces, good to 900F, glop that onto some fiberglass fender repair tape, and you could have success.  I had a muffler shop make some flex couplings that clamp on and they are fine.
John (Boston)
Re: Exhaust joints
« Reply #14 on: March 05, 2019, 10:52:39 PM »
I used stainless band clamps (got them at a truck and bus supply house) and high temp pellet stove silicone.  I put the silicone around the pipe joints and at the splits in the band clamps (which you shouldn't need to do - those clamps seal pretty well on their own).  I still had mysterious exhaust smells from somewhere.
I took apart and remade the exhaust joints.  They all looked good - you could see where the silicone had sealed nicely.  They were a bugger to get apart.  I had already screwed sheet metal screws (with silicone) into the muffler weep holes.  Still had smells.
I thought it might be blowby so I connected the crank case vent to the intake - nope, not that.  Then I thought it might be valve overlap so I extended the intake by four feet or so - nope, not that either...  I gave up and moved the beast out of the house.
Now I wonder if the exhaust was permeating its way through the walls of the house and getting back in from outside.  Because, with the engine outside, if the wind blows the right way I swear I can smell exhaust in the house - and the engine is 50 feet away.  My exhaust pipe only went about 10 feet away from the house (when the engine was inside) so maybe that was it.
The odd thing is that I can run my little Cummins 4BT (in a Step Van) right outside (about 10 feet away) and I get no smell.
-John (Boston)
Metro 6/1 (genset)
Cummins 6BT (89 Dodge truck, bought it new)
Cummins 4BT (91 Oshkosh bread truck)
Kubota D1005 (B2320 tractor)
