Author Topic: injector pump  (Read 575 times)
vegoil
Re: injector pump
« Reply #15 on: January 22, 2019, 01:11:58 PM »
The WVO that I filter is filtered down to 0.5 microns stored in clean barrels and then through a combined clear sediment bowl and filter before the injector pump. over the last 6 months I have yet to see anything in the bowl. The diesel tank and filter are on a separate pipe down to the injector pump. I have the engine running 12 Hours per day about 2 Hour intervals that provides all the heating (storage Heaters) for our House Including two water radiators from the cooling water the radiators produce 3KW heat and they are about 62*C to hot to hold my hand on once the engine is up to temperature. that's between 25 and 30 meters from the engine house. I plan to take heat from the exhaust sometime!
John
