Well done Butch, looks like you are making great progress. How are you going with the arctic weather predicted for you parts of the world?
I have a couple of questions: how is fuel delivered to the fuel reservoir? I am assuming that you would just fill the reservoir manually with about a quarter pint of gasoline, drop on the missing cover and start her up, this would heat the bulb allowing you to switch over to Diesel.
My second question is why there is a need to cool the fuel injector, does it get hot enough to vaporize the diesel? I have seen a lot of fuel injectors on air cooled diesels and never had a problem with fuel evaporating.
Love that Fuel pump, it has more in common with an oil pump than a fuel pump. Can`t believe the good condition of the plunger after more than a century, They certainly new how to make things that last back then. 500 PSI is quite low but I guess that with a large volume, slow speed engine like this, the fuel is vaporized by the heat rather than the injector spray pressure and pattern.
Keep warm,
Bob.
