Author Topic: Pump rack travel as per Lister  (Read 3068 times)
« on: January 13, 2019, 02:16:10 AM »
« Last Edit: August 30, 2019, 12:02:59 PM by 38ac »
Re: Pump rack travel as per Lister
« Reply #1 on: January 13, 2019, 02:23:49 AM »
« Last Edit: August 30, 2019, 12:03:11 PM by 38ac »
« Reply #2 on: January 13, 2019, 02:31:22 AM »
« Last Edit: August 30, 2019, 12:03:25 PM by 38ac »
« Reply #3 on: January 13, 2019, 03:01:13 AM »
A good engine protection feature, missing on my 6/1 Listeroid.
« Reply #4 on: January 13, 2019, 04:36:18 AM »
Sorry for large pics and multiple posts, learning to use  new tablet
Pic shows full rack  1 inch of travel
Hey Butch,  when you have an image open in whatever viewer you use on your tablet - somewhere probably at the top of the screen there will be a little box telling you what percentage you are viewing the image at.  Those ones you posted are large-ish so maybe you are viewing them at 30% or something.  They will be shrunk so the whole image fits on your screen, see?
Somewhere else there will be a tool that says "resize".  If you are viewing an image at, say, 30% for it to fit on the screen, then if you resize it to, say, 29 or 28% you'll see it's a nice fit on screen usually with OK resolution, and a good size to send and for others to open at their end
Just a thought.  Every time you get a new tablet/laptop it takes ages to get it sorted - or that's my experience anyway
Happy 2019, Mike
Engineer
« Reply #5 on: January 13, 2019, 01:32:58 PM »
Thanks for posting the picture, really an interesting little device easily excluded on the India builds.
« Reply #6 on: January 13, 2019, 08:35:55 PM »
On the Mico Bosch pumps used on Indian listeroids, the rack is about a half inch shorter and only has a hole in one end, so over fueling is a very real possibility. I`ve never been able to find a supplier that stocks original replacement racks with twin holes. There is a possibility that a rack for a CAV or Bryce pump would be compatible with a Bosch pump but I`ve never tried it.
« Reply #7 on: January 14, 2019, 12:25:00 PM »
« Last Edit: August 30, 2019, 12:03:41 PM by 38ac »
« Reply #8 on: January 14, 2019, 09:16:25 PM »
Would the Mico Bosch rack fit a Bryce or CAV pump? I have several old pumps with damaged or badly worn racks, I would love to be able to make them serviceable again. The pump bodies are serviceable and new elements are available.
« Reply #9 on: January 15, 2019, 02:12:15 AM »
« Last Edit: August 30, 2019, 12:03:56 PM by 38ac »
« Reply #10 on: January 15, 2019, 03:00:39 AM »
Thank you 38ac, I`ll investigate where to buy a new Mico Bosch rack (twin hole) and let you know how I get on.
