Author Topic: Remote stop  (Read 5090 times)
Re: Remote stop
« Reply #15 on: November 21, 2018, 08:36:37 PM »
Or order something like this off the 'bay, two for less than a tenner and save getting grubby on a rainy Saturday....
https://www.ebay.co.uk/itm/2-Wire-Car-Power-Central-Door-Lock-Actuator-Locking-Solenoid-Motor-DC-12V/253307373233?hash=item3afa4bc6b1:g:1rUAAOSwbF1aLxN~:rk:12:pf:0
Re: Remote stop
« Reply #16 on: November 21, 2018, 09:01:39 PM »
Hey Stef, those look like motor driven actuators- but the current of 4 amps at 12V makes it seem more like a true solenoid. A motor driven actuator would only need 0.1 amps for 12lbs of force.
The CS requires about 10 lbs of force to overcome the governor spring, with a direct push on the rack end. So if their specs of 12lbs are right, these should do it.   My actuators are air cylinders, but that's hardly convenient for most.
« Last Edit: November 21, 2018, 09:05:25 PM by BruceM »
Re: Remote stop
« Reply #17 on: November 21, 2018, 09:37:54 PM »
Hi Stef, would those solenoids have switches in them or would all the switching be done by the central locking controller?
Re: Remote stop
« Reply #18 on: November 21, 2018, 10:45:53 PM »
Stroke is only 20mm- just a bit too short for a CS rack. Other door lock solenoids might do it.
Re: Remote stop
« Reply #19 on: November 22, 2018, 07:57:19 AM »
Hi Bob
I reckon this is the bunny...........
https://en.wikipedia.org/wiki/Power_door_locks#/media/File:DoorAnimation1.gif
Re: Remote stop
« Reply #20 on: November 22, 2018, 09:20:06 PM »
Thanks for the animation Stef, very simple relay switching to reverse polarity on the solenoids. I am assuming that these would have high resistance and draw very little from the vehicle battery/charging circuit.
