Author Topic: JD165 - First Run  (Read 5316 times)
JD165 - First Run
« on: October 16, 2018, 11:32:51 PM »
Hi All,
I just finished my latest project.
A small JD165 air cooled diesel driving a little 2.3 KW head.
The engine makes 3.7HP @ 3000 rpm but I slowed it down to 2000 rpm.
The noise is a little more tolerable when the engine is not screaming.
Fully loaded I expect it to make approx. 1.5 KW which is ideal for powering a refrigerator, freezer, and some light in a outage.
These little engines use very little fuel.
Here is a link to the latest Fall release from Veggie Film Productions  ;D
https://www.youtube.com/watch?v=iBbDhkLJZ64&feature=youtu.be
PS: The exhaust pipe is temporary. I have not yet figured out a muffler arrangement.
Veggie
« Last Edit: October 16, 2018, 11:39:26 PM by veggie »
Re: JD165 - First Run
« Reply #1 on: October 17, 2018, 12:04:24 AM »
Nicely done. Is there still a source for these in North America? I have a little 1.25/1.5 KW gen head I am looking to do something with.
Same idea as you, will run the fridge, lights, and TV/Radio.
« Reply #2 on: October 17, 2018, 12:41:52 AM »
Thanks Bronco,
As far as I know they are not available due to revised EPA regulations.
Same goes for Canada. Craigs List or EBay may uncover the odd one.
Veggie
« Reply #3 on: October 17, 2018, 02:37:45 AM »
Thanks Glort.
Ultimately I want to run it on Veg Oil. And according to your experiences, this should not be a problem with these engines.
(Provided I dose with water from time to time).
Does OZ allow you to import stationary diesels still.?
If so, these engines are available from several suppliers.
cheers,
Veggie
« Last Edit: October 17, 2018, 02:41:24 AM by veggie »
« Reply #4 on: October 17, 2018, 11:42:35 AM »
As usual for you that is very nicely done set. I have one of those engines that was sold new in Canada as a Jeri Diesel.
« Reply #5 on: October 17, 2018, 02:15:48 PM »
Thanks 38ac,
If you open up the inspection cover on yours you will see that they are built like a brick toilet.
Very tough little engines.
Glort,
I was thinking the same thing about the pressure lube system.
I wondered how they lubricated the valve train when the cylinder is angled upward.
Must be a little gear pump in there somewhere.
Veggie
« Reply #6 on: October 17, 2018, 05:38:57 PM »
When is the load test video coming out?  ;D
Will be interesting to see how it handles loads and what it will pull.
« Reply #7 on: October 18, 2018, 02:30:42 PM »
Ahh ! that would be the sequel !  Yes ...
I am currently negotiating with the film crew and editing staff.
I hope to release "Tiny diesel 2" later in the fall.  ;)
« Reply #8 on: July 20, 2019, 09:14:25 PM »
Came across your new video. https://www.youtube.com/watch?v=VYVzJEbizWA
Looks nice with a proper muffler. What generator head is that? I noticed the 110>110/220 switch. That is a pretty nice option for such a small head.
Have you pulled any loads with it yet?
« Reply #9 on: July 25, 2019, 02:22:42 PM »
Thanks Bronco,
The generator head is made buy HC Motor (of China).
I imported a bunch of these a few years back. Sold most and kept 2 for myself.
This one is a mini 2.3 Kw unit and also has auxiliary 12 VDC windings (Notice the red/black connectors on the right side).
The generator engine runs a slow 2000 rpm and generates 1.2 kw of power for battery charging or electric car charging with a class#1 charging cable. If I changed the pulleys and ran the engine up to 2800 rpm it should be able to make approx 2kw.
In a power outage, this little guy charges a car.
« Last Edit: July 26, 2019, 04:54:54 PM by veggie »
