Author Topic: MANUALS OF ALL KIND OF STATIONARY ENGINES  (Read 10906 times)
sirpedrosa
« on: September 30, 2018, 12:25:27 AM »
Greetings Everyone
following the advice of the 38AC, here is open the topic to serve as pool knowledge of engine manuals.
Anyone who needs a manual can ask for it here, and someone who has manuals can share them here, preferably in pdf format.
BEST REGARDS
Pedrosa
Ps: I still need that Petter PAZ1 Instruction Book
By order of firing up:
Re: MANUALS OF ALL KIND OF STATIONARY ENGINES
« Reply #1 on: September 30, 2018, 01:13:13 AM »
The Internal Fire Museum web site has an extensive data base of manuals. Since they are the holders of the Petter factory archives they certainly should have that manual. You must join the site but that is painless and they ask if one downloads a lot of them they would like a donation
sirpedrosa
« Reply #2 on: September 30, 2018, 11:34:11 AM »
Hi 38AC
Thank you one more time, I'll see if it's the way it is.
BR
Pedrosa
Ps: for knowing so much you do not have to have the boot so heavy... you know what I mean.
« Reply #3 on: September 30, 2018, 01:33:43 PM »
I have a PDF workshop manual for  Lister SL and SR if anyone needs it
« Reply #4 on: October 05, 2018, 02:31:46 PM »
We have all the Original Petter manuals from L/P Americas... 100s in stock.
sirpedrosa
« Reply #5 on: October 29, 2018, 09:26:25 PM »
Hi Everyone
You can find more manuals and datasheets here: http://engine.od.ua/LISTER.
BR
VP
sirpedrosa
« Reply #6 on: November 23, 2018, 10:38:38 PM »
Hi Everyone
Someone have Lister DK manual, that can send by email?
Thank in advance.
Pedrosa
sirpedrosa
« Reply #7 on: April 18, 2019, 11:15:50 PM »
Hi Everyone
I found PAZ1, both manuals:
Petter publication 2086/2 and 2086/4 (series 1 versions): http://www.astounding.org.uk/ian/paz1/manual_2086_4_lores.pdf
2086/7 (series 2): http://www.astounding.org.uk/ian/paz1/manual_2086_7_lores.pdf
Saved a copy...
BR
VP
« Last Edit: April 18, 2019, 11:44:21 PM by sirpedrosa »
Listeria
« Reply #8 on: April 19, 2019, 07:02:04 AM »
I’m still searching for anything instructive relating to the Lister JP 1/9 6.25 Kva Startomatic.
Just missed a manual on EBay UK.
Any help would really be greatly appreciated.
I’m currently rebuilding the engine and learning as I go with help and advice from this forum.
« Reply #9 on: April 20, 2019, 04:35:53 AM »
G'Day Listeria,
Start a new thread and ask your questions and put them in a listed form so that who ever has the answer to those questions can make a reply. In the mean time keep a good look out for your manual. A tip that might help is if this manual is hard to get and another comes up, bid hard.
Cobba
sirpedrosa
« Reply #10 on: April 20, 2019, 11:12:28 AM »
Hi Listeria
I found JP's (not JP1), but I think it helps, in: http://www.internalfire.com/
Just register, sign in, and make a donation to get the manual.
BR
VP
« Last Edit: July 01, 2019, 12:09:58 PM by sirpedrosa »
Willw
« Reply #11 on: April 20, 2019, 04:32:22 PM »
Hi Pedrosa, thanks for the links to the PAZ1 diesels.
I too am a PAZ1 lover.
6/1 clone standby generator.
Too many projects.
sirpedrosa
Hi Everyone
JD84 sent RS1 magneto workshop instructions.
Here are they for community.
BR
VP
« Last Edit: July 02, 2019, 10:27:16 AM by sirpedrosa »
sirpedrosa
« Reply #13 on: July 02, 2019, 09:29:17 AM »
« Last Edit: July 02, 2019, 10:27:37 AM by sirpedrosa »
onkelheri
  • "mens sana in carburetor sano"
    • https://www.flickr.com/photos/22328570@N02/albums
« Reply #14 on: August 07, 2019, 11:45:33 AM »
Hello everybody,
It's happened right ... at the classic car meeting in Prüm, a Lister N° 245DHZ10 strayed in my birthday basket ... spurred on by the funny "Steampunkmopet" Lister I stumbled on a Dutch exhibitor about it.
Now I search engine data and technical documents about it ... the WWW / google unfortunately does not give so much ...
Greeting Heri
You can see the running engine ,ok only the Pullywheel on the left site for a second ;.)
https://youtu.be/06t-VdjstFI?t=1503
