Author Topic: Weight of 6-1 with 5kw ST head on frame w/wheels  (Read 3140 times)
cujet
  • Lister power rules!
    • www.cujet.com
« on: September 15, 2018, 03:04:49 AM »
I have this 6-1 setup. I'm moving this setup via truck and need to guess what the weight is. I don't have any method to actually weigh it prior to loading it up in the truck next week.
Thoughts?
https://www.youtube.com/watch?v=a7Kz7uFOm84&t=78s
EdDee
Re: Weight of 6-1 with 5kw ST head on frame w/wheels
« Reply #1 on: September 15, 2018, 08:33:58 AM »
If it's similar in weight to my 12/1 - allow 450 for engine, 40 genhead, 50 base and wheels, plus extra 100 leeway for starter/fans/accessories.... about 650kg at a "zero based stochastic estimate"..... unless the tyres are filled with helium, then it will be weigh less.....
« Reply #2 on: September 15, 2018, 02:35:32 PM »
I saw this generator on you tube at least I think it was this one I was salivating!
queenofjacks
« Reply #3 on: September 15, 2018, 07:19:33 PM »
  I have a similar set-up that I've had to move around, load/un-load, etc.  The engine weighs around 600 Lbs., the Generator head around 300 Lbs. and the rest around 250 lbs.  - so total around1150 - 1200 lbs.  Won't miss it by far! ---- Charlie
Lovson 10/1  7.5KW - Power Solutions 20/2  12KW - Lister SR2 7.5KW - 2-Lister 8/1's - Lister TR2 7.5KW
« Reply #4 on: September 16, 2018, 01:08:14 AM »
I'm thinking a peek at the truck might be interesting.
Casey
cujet
    • www.cujet.com
« Reply #5 on: September 16, 2018, 07:16:09 PM »
Tires are filled with water.
Horsepoor
  • West Palm Beach, Florida
« Reply #6 on: November 12, 2018, 09:12:29 PM »
Chris,
Drive each tire, one at a time, over a bathroom #300 scale. If lucky, you wont break the scale and you will obtain four (4) weight measurements which could be added together to get a total.
