Author Topic: Oversized "Listeroid" interest?  (Read 1200 times)
« on: August 22, 2018, 03:38:33 PM »
Moved this over here from another discussion.
Gary at DES and i have talked about the possibility of importing over sized  Indian single cylinder parts kits for quite some time. Biggest issue is small quantities and dealing with his exporters. What I mean by oversized is bores and strokes in the 155mm x 177mm range  generally  rated 18-22 HP  although actual specs  vary a good bit from erector to erector.  These engines share no parts with a CS clone or smaller listeroids. An example is shown in this video https://www.youtube.com/watch?v=XXPnBb-waZ8 As you can see they are a good bit larger than a CS or clone.
Posting this as a primer for anyone who might have interest. As Gary said in the other thread, if enough committals are made then the process might move forward.
Re: Oversized "Listeroid" interest?
« Reply #1 on: August 22, 2018, 05:41:49 PM »
There are a few issues to resolve on both sides of the pond. In India, the tax incentive and regulation goes to providing complete finished product, current regulation in the USA allows only parts and pieces. Gaining willing cooperation of the business network in India is possible, but can be difficult at times. If I thought we could sell at least 6 units, I would be willing to tackle the full container once again. We usually fit about 30 to 40 units in a 20' container.
« Reply #2 on: August 22, 2018, 07:46:58 PM »
Ship the whole engines to the Philippines and then ship the "kits" from the Philippines to the US?
dkmc
« Reply #3 on: August 22, 2018, 08:22:09 PM »
I have enough interest to say, please keep this discussion going.
Pricing info would be helpful if/when that's available.
What is the 'other' thread that spawned this one?
« Reply #4 on: August 22, 2018, 08:44:59 PM »
balance on a single 6/1 is tough/impossible, what's it like with a oversize single, what bolts are required to anchor it?
EdDee
« Reply #5 on: August 23, 2018, 08:39:07 AM »
@mike90045
Balance it properly and it tames from a wild whirling dervish into a smooth, trembling and meek slave.....
Ed
« Reply #6 on: August 23, 2018, 11:04:44 AM »
Excuse the genuine if simplistic question but what would the advantage be of one of these engines over the other comparable in say Kubota's, yanmayrs or other diesels of the same sort of output?
By the looks of the ones in the vids, the "megaroids" are not slow, they are not quiet, their longevity is not determined, they would be very heavy, take up a lot of space and may well have the typical issues of normal Roids.
Looking on fleabay, I'm not seeing any shortage of decent small ( or large) diesel engines.
EdDee
« Reply #7 on: August 23, 2018, 11:09:55 AM »
Aaah.....but those little things without big wheels aren't chick magnets.....
« Reply #8 on: August 23, 2018, 11:21:31 AM »
BWAHAHAHA!
 :embarassed:  Well how could I have over looked that glaringly obvious benefit?
Just took it for granted I spose!
« Reply #9 on: August 23, 2018, 02:39:30 PM »
Run them at 650rpm - not slow?
Balance and exhaust them through a good silencer system, not quiet?
Weight and space? Maybe not relevant factors for everyone.
Longevity - depends on your build quality... the design has some history and as far as I can fathom, is just an upscale of existing proven technology.
« Reply #10 on: August 24, 2018, 12:22:42 PM »
As they said, nothing but a big boy toy, at least for me.
mcreeferson
« Reply #11 on: October 05, 2018, 06:19:52 AM »
I might have interest in a ste-roid if you caught me on the right day and the price was right...
« Reply #12 on: October 06, 2018, 10:00:48 AM »
Interesting that the Indians have been able to produce such large single cylinder engines, personally I would have thought it easier, and cheaper, to build a smaller twin cylinder unit. All very well increasing the bore and stroke, have they increased the size of the crankshaft, bearings and housings to cope with this extra power output? How big a man and starting handle do you need to swing an 22/1 into life? Unless they get the balancing right it will quickly destroy itself, alternatively it will destroy the foundation it`s sat on before exiting the building and laying waste to the neighborhood.  :laugh:
« Reply #13 on: October 06, 2018, 06:11:34 PM »
As with all decent builds, you must address proper balancing. Starting is very comparable to any of the smaller displacement units. You have a little more reciprocating mass, but you spin that portion up to speed with compression released and then just let the rotating mass carry it through the first starting impulses when you close the exhaust valve. It has heavier flywheels to help make it happen.
mcreeferson
« Reply #14 on: October 28, 2018, 01:16:16 PM »
Got a good chuckle out of that one. Had a good mental image of a giant green chunk of metal bouncing around the neighbor’s yard.
