Author Topic: Micro power gen  (Read 11185 times)
Re: Micro power gen
« Reply #30 on: August 31, 2018, 09:46:59 PM »
With hydro, you have to be aware of intake screens getting plugged up and loosing flow.  Daily checks are the norm, till you learn how well it's going.  When raining, windy or leaf fall season, much more frequent checks are needed.
Any danger of icing up and loosing all flow, or nozzle being split from ice ?
Re: Micro power gen
« Reply #31 on: September 01, 2018, 03:49:35 AM »
the older power spout site, used to have a calculator for head/flow wattage
Re: Micro power gen
« Reply #32 on: September 01, 2018, 11:03:26 AM »
Depending on the site and the flow you can always build a sluiceway and a water-wheel?
Then there are no issue around ice, leaves, stones, dirt or any of that stuff
The price of that simplicity is that the efficiency is half that of a well-designed pelton-wheel . . . .
But the maintenance and fragility is about 1% of what it would be with a pelton, screens, water pipes, adjustable nozzles . . . .
Just a thought
Re: Micro power gen
« Reply #33 on: September 01, 2018, 04:17:51 PM »
Hi Glort.
Nice to know that we could plot a course to Mars, well if we got Bruce to run the calcs!
Mike.
I'd dearly love a big ol' overshot grinding away on the SW side of the barn, there's even a case for it, when the barn was built it would have had a small man made canal to it, there are dozens of kilometers of them in our valley and there must be thousands of k in the Pyrenees as a whole, to provide water for the stock. There is a provision in the local agrarian bylaws to the effect that it's incumbent on a land owner to maintain them. Sadly, since mechanisation loads have been lost, and one of them served the barn I'm after.
The other problem is that a water wheel would want way more water than I'd be happy redirecting around the point where they pick up the valleys water supply. provided I don't ruffle the Mayors feathers I'll get away with quoting historic rights for just a fraction of the supply, in the unlikely event that someone notices and cops the hump.
Re: Micro power gen
« Reply #34 on: September 01, 2018, 04:49:44 PM »
I did some checking and direct AC generation with frequency regulation via load is common and popular; it seems Glort nailed it.
http://www.homepower.ca/ac_hydro.htm
I think with some diligence you should be able to find a completely tried and tested system to do what you need, Stef.
Re: Micro power gen
« Reply #35 on: September 02, 2018, 01:42:43 AM »
Hi Glort.
Mike.
Yep, you're right Stef
Probably the first question is "how many watts do I need to generate?"  And, of course, the answer is different if you have direct generation-to-house or if you have batteries and inverter(s)
If the latter, then a kW or so is probably fine 24/7 - which is the benefit of hydro, of course
Obviously I don't have a picture of your setup - but if there is steady flow, then there are many ways to build a channel and an undershot arrangement (if there is no fall but if there is flow) or an overshot if there is fall as well
Would it be possible to retain the flow of water to other users with an undershot something?
There are many youtube videos of wheels in the one-metre-diameter range; usually very poorly engineered by uninformed optimists but which demonstrate an ability to generate rotary motion from not-very-much
this sort of thing but better
https://www.youtube.com/watch?v=vZAVBaGryPA
Something like 300 watts 24/7 is probably equal to a solar array with a peak of 1500W when the sun shines, nothing at all in darkness, almost nothing when overcast and running at 15% output on winter days
Re: Micro power gen
« Reply #36 on: September 02, 2018, 03:47:51 AM »
On Alibaba there were seems to be plenty of turbines with generator in the 3K region.
What I haven't seen is load management/regulators but I didn't spend much time looking for that.  It could be just an Arduino Uno, a frequency detect circuit and some solid state relays.
I'd be glad to help if need be, Steff.
Re: Micro power gen
« Reply #37 on: September 02, 2018, 12:56:17 PM »
Hi All
No Glort, I'm not confused, overwhelmed, maybe!
This is exactly the type of thread I was looking for, it's a bit like a bunch of like minded engineers sat in the tea hut (or coffee hut in the US) working their way around some naval architects idea of a bilge and ballast system more suited to the Starship Enterprise, in order to get a practical design to suit the job in hand and still keep it under budget without pissing the management off.
And I get to cherry pick from the brains of people who's opinions I value before I cock it up all on my own!
It's going to be simple and hopefully inexpensive. Sure there's 5Kw of power to be had but I'm happy to use what's there inefficiently, as it's 'free' and live a relatively 'low wattage' off grid life. The barn will be a second home and if it's bloody hard work to live there in the winter months, we won't be there.
What ever happens it'll be fun, please keep the ideas coming..........
Cheers Stef
Re: Micro power gen
« Reply #38 on: September 02, 2018, 04:07:58 PM »
The economics of infrastructure cost (pipe run) would be the only thing that might steer me into batteries and the puny 1000W battery charger.  If the pipe run is not too long, then direct AC generation is hands down winner in my mind.  The simplicity and power of the direct AC generation and value of the substantial heat from the regulation system are very tempting, and the savings on batteries (the replacement cost goes on forever) is the clincher.
Re: Micro power gen
« Reply #39 on: September 02, 2018, 06:22:25 PM »
Thanks both,
Here's where I'm at so far,
1000w will be great, and, given what I've learned so far the 24 volt alternator is favourite, along with a couple of 150 ah deep cycle batteries. the idea of a 220v system without batteries is very tempting, especially with the offer of help with the design of the control panel.
I'll start scrounging up stuff and see where it all leads. As it's a 'project' rather than the next full time home, the funds are limited
It's going to be a 3 year project, minimum, we've had a mate staying with us this week and he's talked me into doing a 'Frank Sinatra' and coming out of (semi) retirement for a self propelled hover barge project, with a build in Scotland and trials on the Caspian next year. There's the advantage of some decent money against that of having to work in Kazakhstan on a four week rotation.
Keep the ideas coming, I still don't own the barn yet!
Cheers Stef
Re: Micro power gen
« Reply #40 on: September 02, 2018, 07:36:56 PM »
If the place is to be a vacation cabin, you may find that a modest PV system with generator backup is far less costly.  The infrastructure cost for microhydro can be a substantial compared to screwing a few panels on your roof.
The hover barge project sounds awesome!
Re: Micro power gen
« Reply #41 on: September 02, 2018, 09:41:31 PM »
Hi Bruce.
The idea is for something like a summer residence, initially. we will only be 2k from our B&B. Which we'd like to let it out as a 'gite', a self catering holiday home, by the week, in the summer. That way we'll only have to come down once a week to sort the place out for the next guests, rather than be tied up 24/7 with breakfast, evening meals and people coming and going every couple of days. less money, but less work, we're not getting any younger!
The rules for conversion won't allow solar panels - don't tell Glort, he'll be mounting an attack on our local planning office! - and the water source is just on the other side of my boundary, so what ever I do has to be a bit discrete.
From what I've learned so far, a truck alternator, a couple of batteries and a home brewed hydro plant will be less than €500, I can pick up a couple of hundred meters of irrigation pipe for around €300, second hand, allow €300 for an inverter and another $200 for some cabling ect. and Robert is your mum's sister's live in lover......
If life unfolds anywhere near where I'd like it to, once the project is livable, going down the load controlled genny route, with a slightly larger pipe would be the way into the future.
Google 'hover barge at Fergusons shipyard' for some images of the last one I worked on, 'The Siberian'
There's not been many built, but they've been about for years, try this for awesome....
https://www.reddit.com/r/aviation/comments/52tleq/columbia_helicopters_vertol_107ii_towing_a_hover/
Cheers Stef
Re: Micro power gen
« Reply #42 on: September 02, 2018, 10:16:40 PM »
I wondered why a hover barge until I saw the ice.  Awesome machines.
No PV sucks, I can see why a small discrete microhydro is appealing.
Re: Micro power gen
« Reply #43 on: September 03, 2018, 07:14:38 PM »
Hi Glort,
Yep, that's exactly what it is, whilst we're not quite in the Pyrenees National Park we're close enough that the local authorities want to keep it pretty for the tourists, sheep and tourists are the two staples industries here.
As I said I'm liking the 24v route, so I think that's what I'll start scrounging for first.
If I end up in Scotland it'll be like a free pass to Aladin's spare gear store and workshop, if it's anything like last time I was there..........
Cheers Stef
