Author Topic: Solar water heaters.  (Read 8445 times)
old seagull man
Re: Solar water heaters.
« Reply #15 on: April 09, 2019, 01:24:49 PM »
A link some my find interesting, much has been covered, by Glort.
But interesting reading, and we all love more information, don't we.
http://waterheatertimer.org/index.html
« Reply #16 on: April 09, 2019, 02:27:26 PM »
I was reading about a guy in Canada recently who linked to a vid on PV panel angle.
Due to the odd occasion when it snows and everything gets about a 1M buildup, some Canadians have found tilting their panels 90o, Straight up and down has worked well for them.
The tilting of of the panels to a vertical position (90 degree from horizontal) is to capture the low winter sun.
Here in Canada (Especially northern Canada) the sun does not rise much above the horizon through the day.
Some orient part of their array vertically and part of it angled upwards. Others build a winter/summer angle adjustment into the array framework.
The rule of thumb here is to angle the panels at the same value as your location latitude +5 degrees.
So if you live at 55 degrees north, then angle the panels at 60 degrees for the best year round performance.
There are many application of evacuated tube solar water heating systems here.
They work very well in winter.
« Reply #17 on: April 09, 2019, 02:38:24 PM »
Here's an example of an application in Calgary, Canada which provides winter home heating.
Notice the steep angle of the panels to capture winter heat as efficiently as possible.
https://www.youtube.com/watch?v=CTpEj5XPpc0
« Reply #18 on: April 09, 2019, 04:39:43 PM »
Mikenash, yes, resistive heating elements will work just as expected with the rated RMS voltage of DC or AC.  The DC voltage must be regulated in some manner, and this kit is not commonly available, so AC operation is common.  If there is a dedicated PV array for a water heater element, matching panel array voltage to element voltage should be sufficient as long as you keep at or below the heating element voltage.  PWM regulation is also possible but I haven't seen a commercial DC to DC converter of that sort of capacity and voltages. DC switching on the low voltage leg is simple via HV mosfet(s).
Thanks for the great links on VE hot water Veggie. Vacuum Evacuated hot water collectors can be a DIY project, as Carl showed us years ago. A great solution for cold climates; flat panel collectors are by far the most economical where winters are mild to moderate.
« Reply #19 on: April 09, 2019, 05:08:03 PM »
Thanks Bruce& others.   Good thoughts
« Reply #20 on: April 09, 2019, 08:54:15 PM »
Hi Bruce
Thanks for taking 2 minuets of you life to explain to Mike that you can run an immersion heater on DC.
I've just used up 4 minuets of mine reading about RMS, the Wikipedia page had some great Greek symbols, gotta love that sigma....
If it was down to me I'd run my solar power into a small 12v battery bank through a solar charge controller, with a low voltage cut out feeding the  inverter supplying the immersion heater, this I think I understand!
A. Would it work?
B. Is the gain, from a 100w panel for example, enough to make the system worth while?
C. Am I just being lazy and trying to avoid complicated formulas and a bit of soldering?
Cheers Stef
« Reply #21 on: April 10, 2019, 05:55:30 AM »
12v is great stuff for circ pumps, controls, audio, but it's pretty grossly inefficient for real power.  24 is 12V's bigger sister but still, it's crap for much inverter power.  The amps just get out of hand.  48V was a better but still poor choice to allow non-electricians to do PV installs.
I just skipped back to the future and went to 120VDC.  My computer and rear projection workstation are running on it now, with stock power supplies.  This is handy in the US as many small kitchen appliances, as well as soldering irons, work nicely on 120VDC.  I have a coffee grinder, stick mixer, and other goodies that do just fine.  Brushed motors which have some current interruption and inductive kickback allow the original switches to work fine.
Most US Data Centers have gone 350VDC, which is compatible with switching supplies designed for 230VAC.  They chose the highest practical voltage for the coolest running supplies, and largest battery capacity.
BuilditSolar.com has some good articles and comparisons of flat plate vs evacuated tube collectors.  The need for higher water temperatures (I don't need more than 80F to heat the house) might be an issue that forces evacuated tube.  Flat plate is easy and economical to build- my aluminum fin over copper pipe collector is right out of their designs.
« Reply #22 on: April 10, 2019, 09:27:53 AM »
Interesting thoughts, gents.  Two minutes here, two minutes there
I'm a fan of low-tech.  Having the luxury of living largely on my own I can please myself about how I live when I'm not at work.
In summer there's solar hot water.  My electricity needs are lights, fridge, phone charger.  Power tools?  I'll run a generator
In winter there's the wetback that heats water in the 180L cylinder.  Often I'll be away for a week or two and the water in that cylinder is at three degrees when I get there.  There is good sun in the crisp winter days & it seemed to me maybe a couple of panels could push a few 24VDC amps into the element there when they had nothing else to do without doing anything any real harm . . .
The fire in the woodstove pumps out heat a lot better if the water in the wetback is at 30 degrees rather than 3 degrees initially
Thanks for the inputs
« Reply #23 on: April 10, 2019, 02:23:03 PM »
BruceM, that's very interesting.
Using 120 vdc really reduces wire size in a big way.
120 vdc would work very well when applied to a 120 volt water heating element.
(Although switching on/off 120 vdc with any substantial amperage may be tricky)
1] Is your 120 vdc derived from a battery bank? or are you pulling 120 volts from a solar array?
If it's an array, how are you regulating the voltage as the array output varies?
2] How do you run your computer on 120vdc?
cheers,
Veggie
« Reply #24 on: April 10, 2019, 02:30:37 PM »
Sounds like a good plan Mikenash, but your PV to element power may be very low if the PV voltage isn't within the ballpark for the element.  The power curve for your proposed panels will be given by the manufacturer.
PS, a small 12/24v system for a cabin is the exception to the 48v rule.  I still strongly advise keeping batteries and inverter out of the cabin, and PV for same off the cabin roof.  Then at least add a commercial 2 or 3 stage filter on the AC going to the cabin. Better, also put cabin wiring in EMT conduit with compression fittings.  There is growing independent research supporting that our brains are directly affected by radiated emissions, affecting endocrine and other systems.
Veggie, my 120VDC system has 10- 12v batteries in series, and battery management to the 12v level similar to early EV systems.  Awesome battery life.  I'm not regulating the 120VDC, the switching supplies don't care.  Lighting is incandescent soft whites, 60 or 100watt. They get used mostly at night when voltage is more like 126v.
« Reply #25 on: April 10, 2019, 06:03:31 PM »
Water heater elements don't care about AC or DC
The Thermostat is a problem.  using DC on a AC thermostat will fry it pretty quickly.
Matching your PV voltage to the heating element voltage helps. Putting 12V into a 120V element will not do much heating, like hooking a 120v bulb to a car battery, you might see it glow a bit, but no usable light
« Reply #26 on: April 11, 2019, 02:20:39 AM »
There are solid state relays for switching rather massive amounts of DC, though I make my own since it cheaper and I can have just what I want.  Just make sure they provide the "on" resistance, so you know how much heat sinking.
It's not a bad thing to learn how to use a MOSFET transistor for switching DC power.  Plenty of tutorials on line.
Not much power required to warm up an insulated tank if you can wait days.  Heating watts are just volts times amps, and the resistance of the element is stated or can be calculated via ohms law.  The power curve of the panels allows you to accurately predict voltage at a given amp load.
« Reply #27 on: April 11, 2019, 07:16:12 AM »
Bruce, Yes, thanks
When I fitted the wetback cylinder I took out the element and fitted a low-rated 1500-watt one.
I have had lots of experience with these fairly modern, relatively well-insulated cylinders.  In my last house, in summer, I'd run the wetback on a Sunday while I was doing outside stuff so the heat of the fire didn't annoy.  Once the cylinder was almost boiling I'd turn it off.  They hold heat well and some kind of thermocline process stops cold & hot mixing as you use hot water (obviously, cold water enters at the very bottom and "pushes" hot water out the top).  Often there would still be acceptably-hot water for a shower on the following Thursday
So when you put heat into the water in the cylinder it holds it quite well
If I'm away for a week and the photovoltaic is connected direct to that 1500w element, it can pop a few amps into it at 24 - 40 VDC all day long, and whatever temperature rise it may manage will still be 90%there the next morning when the sun shines again
(no thermostat - it wouldn't like that)
When I turn up on Friday night the water temp might be 10 degrees, or 20 degrees, or 30 degrees?  Who knows?  It's probably gonna be an improvement on two degrees, anyway.  A "head start" for the wetback, really
If it does bugger-all then I guess I've wasted an hour with wire & screwdriver
Next time I'm up there I'll have a tinker with the meter and see what actual voltages come down the line into the controller.  Who knows?
If you have (a) no money, (b) off-grid, and (c) the luxury of pleasing yourself how you do things - you can do quite a bit with creative use of small amounts of energy (LED lamps might be an example)
I guess we'll see.  There's a stand-alone panel I can have a play with easily.  If it makes, say, 5A at 35VDC, then there might be 10% of the nominal wattage of that 1500W element tricking into the water . . .
« Reply #28 on: April 11, 2019, 08:51:04 AM »
Thanks for that guys,
I read up more on RMS and now have a bit of a clue as to what it all means, gotta love the university of Google!
No Money and little power is where I'm -slowly - going with the barn up the hill.
After almost a year I'm getting closer to buying it, the outfit that controls the refurbishment of ancient barns have given me permission for the conversion but the local council won't give me the go ahead 'cos the first lot put a caveat on the permission to the effect that I cannot remove any soil to construct the track.
This is a bit of a sticking point as the last 40 meters goes up at about 1 in 4, and the only way to get a track suitable for vehicles is to put in a hairpin bend. Big digger and loads of soil movement!
So yesterday I went back to our 'county town', Tarbes, and got the name of the boss who, naturally, wasn't there. At least I got to speak to an underling, who was very nice but totally non committal, and came away with an email address to try and get an appointment. Amazingly my French held up pretty well, tho having a partner who is extremely fluent helps......
Although I've shaken hands on the deal I've said I won't finally commit until all the permissions have been granted and refusing to pay an architect €6500 has cost me time rather than money, with a bit of luck another 5 months should do it!.
In the meantime I've been keeping an eye on the stream and it seems to be fairly constant, even in the dry spells, so the mini hydro plant is still looking favorite.
I'm leaning heavily in the direction of driving a 24v truck alternator with a pelton wheel, running it straight into a pair of 120 ah 12v truck batteries and out through a 6000x inverter. The idea being everything is plug and play, relatively cheap and easy to install. It's also very familiar to me as it's essentially the same as the system I had on my Dutch barge.
I don't know if it has any merit, but I'm also thinking of installing a second loop of under floor heating pipe alongside one driven by the wood burner. The - vague - plan is to power it with the output of the alternator in the early morning dark hours, once the batteries are topped up. Nothing complicated, just a timer, circ. pump, 24v immersion element and a temperature controlled switch to cut out the element if the pump packs up and / or it all gets too hot.
I got the idea from Glorts ponderings on 'what to do with excess solar power'
Bit of a long post for me, you won't believe how crap my typing skills are, I'm killing an hour whilst waiting to set off with a mate's truck for the French vehicle control test!!
« Reply #29 on: April 11, 2019, 09:35:00 AM »
Well done, Stef.  Fascinating as always the lives of folks here
