Author Topic: PETTER - PAZ1 - New project  (Read 57220 times)
Re: PETTER - PAZ1 - New project
« Reply #60 on: April 16, 2019, 12:57:36 PM »
Hi VP, sorry not to have been in touch but I`ve been in hospital.
Stef is right, if you can cool the shaft and heat the flywheel it will come apart. You could mount it in your new hydraulic press. If all else fails you could buy a pipe freezing pack from you local plumbers store, this should get the shaft down to around minus 20 degrees centigrade. If that does not work, run a large bead of weld around the outside of the flywheel boss with an electric arc welder, do it both ends of the boss. You will have to grind the weld material off later but who cares how you got it off as long as it is off!
sirpedrosa
« Reply #61 on: April 16, 2019, 09:48:47 PM »
Hi Everyone
It's done... finally, like Jim Perkins said. And that piece of spring blade gave utility. And yes, I gave it some heat in the flywheel
Let's go up!
By order of firing up:
« Reply #62 on: April 17, 2019, 12:39:50 AM »
Well done VP, hope you didn`t damage the concrete floor.
sirpedrosa
« Reply #63 on: April 19, 2019, 12:11:31 AM »
Hi Everyone
Hello Bob, is that hand recovering? Everything went well, The floor had the card board, that piece of truck spring blade with 2cm thickness, and above a piece of MDF for cushion.
Now it is begin to remove the parts from the basket, primary paint, and then enamel MBG. Cutting paper joints, puting screws...
One day at a time.
PS:Bob answer to email I sent.
« Reply #64 on: April 19, 2019, 02:14:00 AM »
I`ll check my email.
bob
sirpedrosa
« Reply #65 on: April 20, 2019, 12:42:41 AM »
Hi Everyone
Special thanks to Bob, and a wish of a quick recovery of his hand, (he will need it!).
There's nothing like seeing a machine "dressing up". Take a look!
Have a holy Easter, or another celebration that reminds us that Saint Peter will need to illuminate Paradise with, maybe  a CS or, perhaps, a Petter...
Be Happy, please.
« Last Edit: April 20, 2019, 12:45:19 AM by sirpedrosa »
sirpedrosa
« Reply #66 on: April 25, 2019, 10:45:16 PM »
Hi Everyone
Just updating work:
Straitening oil piping, and make trolley project (on old milimetric sheet)
Be happy
« Last Edit: April 30, 2019, 01:26:05 AM by sirpedrosa »
sirpedrosa
« Reply #67 on: April 27, 2019, 12:19:45 AM »
Hi Everyone
Today was a good day.
I finally managed to find a store that produced the MBGreen painting.
sirpedrosa
« Reply #68 on: April 27, 2019, 12:20:56 AM »
Before painting I had to repair the "office clothes", sew holes and put elastic for protection.
sirpedrosa
« Reply #69 on: April 27, 2019, 12:21:21 AM »
I still have a headache to solve, and remove the broken gibkey.
sirpedrosa
« Reply #70 on: April 27, 2019, 12:22:34 AM »
No doubt that green is really beautiful ... see the "clothes-line"
Things are going...
Have a nice weekend.
sirpedrosa
« Reply #71 on: April 27, 2019, 11:46:37 PM »
"He's taking shape!"
the other one is taking "plan B" on that gibkey.
« Last Edit: April 30, 2019, 01:19:52 AM by sirpedrosa »
sirpedrosa
« Reply #72 on: April 30, 2019, 01:19:20 AM »
Hi Everyone
Some more work: oil piping done, cylinder and head "torqued".
A pair of pics for the enthusiasts.
Willw
« Reply #73 on: April 30, 2019, 12:03:37 PM »
Good work.
I'm looking forward to hearing it run.
6/1 clone standby generator.
Too many projects.
« Reply #74 on: April 30, 2019, 08:15:57 PM »
It's starting to look pretty!
