Author Topic: Ashwamegh 25/2 :ever feel stupid ?  (Read 3116 times)
32 coupe
  • "Doc Johnson" on call !
« on: August 11, 2018, 07:30:17 PM »
As some of you know I have had a problem with the engine pulling a load.
Anything over about 1kw and it would just fall flat.
After playing with about a dozen springs and sending the cam to Butch for
a rebuild with new weights and a new lobe I still could not get it to work.
When I got the "new" cam installed I, of course, set the valves but not the injection
timing. Today I set the timing (it was off a few degrees) and re adjusted the valves.
I saw a slight difference in exhaust temps so I did a fine adjustment on the linkage
and got the exhaust temps nearly perfect.
Off to pull a load.....no help......
I have often had the seals on the crank at the bearing housings squeel a little. I put a drop
of oil on them and that will stop. I believe it is because I run the crankcase vent to the intake
manifold instead of the "spring valve" the engine is shipped with.
Any way.....I noticed a very slight squeel while running. Ever so slight......
When running I watch my "kill a watt" and don't check rpms......
Today during testing I installed 1 of the 2 belts I run on this machine....
I thought I should install the other belt to see if the noise would go away......
Well, well, well......the slight noise did go away......
The engine will now pull a 5kw load with about a 1.2hz drop from no load to loaded.
I know the cam change was not a mistake because when I ran it before I always ran 2 belts.
So it looks like I am getting very close. After I got the belts on I took off the 3 springs I had on the
govenor and installed just 1. It is close but not as good as with the cobbled 3 springs in place
so it will take a little more work in that area.
I had to stop today because it is starting to rain and I run it outside but I know I am getting close !
Thanks for everyone's input. I couldn't ask for a more knowledgeable bunch of guys !!
« Last Edit: August 11, 2018, 07:34:03 PM by 32 coupe »
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
Re: Ashwamegh 25/2 :ever feel stupid ?
« Reply #1 on: August 12, 2018, 11:15:37 PM »
What's it do when you de-restrict the intake?  No hose or adapters?  Couldn't hurt for a few minutes could it?
« Reply #2 on: August 13, 2018, 03:16:54 AM »
Loose or badly-tensioned belts will lose you power - or the ability to transmit power in all sorts of odd ways that aren't always obvious
If you have two belts running like that you really need to have a "matched" pair (two belys cut from the same "slice" of belting, otherwise, if one is a little tighter than the other, you are effectively just driving with one when the load comes on
Also, and excuse me if this is a stupid suggestion, but are you sure the belt groove machined in the flywheel or on the driven pulley is the correct groove for the belt you are using?
That 'squeal" or "chirp" is a classic symptom of a loose belt initially slipping when load is applied
It may be, also, that if you have been running it with just one belt - than that one belt may be stretched/worn past the point where it is a good "match" for the other belt and - although you may not want to do so - the right thing to do might be to replace both with a "matched" pair
Some of the engineers here with better drive skills than me will chime in here . . .
32 coupe
« Reply #3 on: August 13, 2018, 04:20:12 PM »
I think they are called "common back" belts.....
I am runing a new "b belt" pulley on the gen head and running the belts on the flywheel face.
I questioned this method but I see several done in this fashion with success.
I played with it a little yesterday and after a belt adjustment and playing with 2 springs on the
gov I get about a 2.5 hz loss between 0 load and 5kw.  I would like to get it closer and will play
with it more in the future.
I adjusted the valves on the engine per Butch's method and it does seem to run a little better ?
In answer to the other question : The picture is from the coolong side....intake and exhaust are stock.
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
32 coupe
« Reply #4 on: August 14, 2018, 01:07:14 AM »
« Last Edit: August 14, 2018, 01:11:19 AM by 32 coupe »
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
« Reply #5 on: August 14, 2018, 03:48:49 AM »
Gary
My apologies - I hadn't taken from the photos that the B-belts ran on top of the big drive pulley - I had assumed there were grooves machined (hence my comment on groove and belt profile compatability
There will be other with direct experience of this method - and they will be better-informed than I am
However - just from an engineering POV I would guess the drive contact area provided by a flat-on-the-surface approach would be maybe 1/3 of that provided by belts running in suitable grooves?
Also, since the grooves have tapered walls and the belts have tapered sides, when the "load comes on" the belts will pull into the grooves - if you watch videos of loads being applied in hundred-horsepower applications and the like you will see a surprising slackening of the belts on the non-drive side (enough for them almost to "flap" sometimes) - and, obviously, this is single-digit HP application here, but I suspect the principle will be similar?
It may be there is a limit to the response you can get from what might be a fairly casual belt set-up if you have inherited it?
That "chirp"  and the difference in response between one belt and two are clues - and to me they suggest you're not getting power because you're not getting drive?  Maybe?
A transmission company person would be able to advise . . .
If it was a factory application I was responsible for I would be looking at:
Belt condition
Belt tension (try it tighter than you think is good, and see what happens, maybe?)  Also, there will be deflection charts online to allow you to gauge correct tension for given belt types between given centres
Belt match across the two of them
Consider using "belt grip" aerosol to have a play and learn something?
Maybe have a good look at the faces of the grooves in the driven pulley for wear or grooving?  "Drive" depends on the ability of the belt and groove surfaces to match nicely
Just some thoughts . . .,
« Reply #6 on: August 14, 2018, 04:07:51 AM »
I tried a single B belt on a non-grooved flywheel for my neighbor's DES 8/1 conversion to propane/spark.  This driving an ST-3 with a B pulley.  It works fine, and requires much less tension than my Listeroid 6/1 with microgroove belt.  In either case, slippage on the huge Lister flywheels is absolutely not a problem. The B section belt has plenty of flat surface on the inside, unlike A belts.
Having done it both ways, I go with the cheaper, which tends to be B belts and pulleys here, but either works fine and I'd not turn down a microgroove pulley/belt bargain.  I like the lower tension required on the B belts, and think it may improve bearing life.
« Reply #7 on: August 14, 2018, 05:12:05 AM »
Cool
I'll watch with interest to see how it all turns out
Looking at the side-loads on bearings from that drive, I ended up building a stub-shaft with a couple of bearings and a coupling to the generator head for that very reason, as we have discussed previously
« Reply #8 on: August 14, 2018, 12:23:23 PM »
I had an MGB GT many years ago, I fitted a very expensive stereo system to it. Surround sound system rated at 250 watts RMS per channel. On the motorway I could slow the car down by turning up the stereo. Never had a problem with alternator belts but had no end of flat batteries! :laugh:
