Author Topic: Identify this part....  (Read 2081 times)
guest22972
« on: August 07, 2018, 02:30:08 PM »
This was advertised just up the road from me so I thought I'd get it for the shed/ mancave wall.
Anyone know what it is?  Not a competition, I have no idea. it's listed as a flywheel but seems unlikley.  Just wondering if anyone can tell me what I have bought!  :0)
dax021
Re: Identify this part....
« Reply #1 on: August 07, 2018, 03:15:40 PM »
How thick is it?  Looks like it could be a wheel for a cart.
« Reply #2 on: August 07, 2018, 10:35:01 PM »
I reckon it's the plate which retains a circular piece of "sandpaper" onto a backing plate on a grinder which is used to sharpen sheep-shearing cutter combs on "Lister" shearing power plants?
Here, and probably in Australia - Lister engines were used for decades to power shearing plants, and the company branched out into small mobile petrol-powered shearing and dagging plants, grinders, accessories etc etc
Check out the grinder attachment on this unit - see the shaft and nut?  I THINK your plate goes on something like that
https://www.trademe.co.nz/antiques-collectables/other/listing-1722788724.htm?rsqid=7df0c6f1d9a14f11bf543be55458821d
I could easily be wrong - after several decades of being married to a schoolteacher I am well accustomed to being wrong . . .
ronmar
« Reply #3 on: August 08, 2018, 12:01:17 AM »
Cover for some type of filter housing or a case access cover?
PS 6/1 - ST-5.
« Reply #4 on: August 08, 2018, 09:12:01 AM »
What diameter is it and does the other side look the same or is it flat? If it`s flat and around 600 mm diameter it is probably a pedestal of some sort. If the other side is the same then it must be some sort of flywheel, probably off one of the Lister shearing plants. If it`s only small in diameter then it is probably for sharpening shearing equipment.
« Reply #5 on: August 08, 2018, 11:29:01 AM »
Looks like a hub cap off one of the early CS driven flying saucers as piloted by Dan Dare in the late 30's to me...........
Cheers Stef
oldgoat
« Reply #6 on: August 08, 2018, 12:44:36 PM »
Mike is right I have an identical one on my crutching plant.
