Author Topic: Resurrection of a Lister 12/2  (Read 6037 times)
sirpedrosa
  • Just one more day hoping to hear that sound
« Reply #135 on: November 24, 2018, 12:59:38 PM »
Hi Everyone
Got the fuel filter adaptar done! Nice piece.
PS: Lathe bill takes away a few good bottles of red and green...
« Last Edit: November 24, 2018, 01:06:42 PM by sirpedrosa »
« Reply #136 on: November 24, 2018, 10:48:10 PM »
Hi Pedrosa, very nice work, love to see some polished brass rather than the normal cheap cadmium plated steel crap normally used now.
What is the make and number of that fuel filter so I can do the same ?
Sorry to hear the cost of parts and machining services is reducing your alcohol consumption. Stick with it, it will be worth it in the end.
sirpedrosa
« Reply #137 on: November 24, 2018, 11:33:05 PM »
Hi Bob
Popular name for this filter is kx9 (Mhale) - and is a general porpose fuel filter for a huge number os automotive brands.
I showed it in Reply #67 - In AU you can buy a C4891 FRAM (view equivalent chart https://www.pecasauto24.pt/mann-filter-7280260.html)
About the brass, I had to buy the material for turning. The 3/8 pipe had to buy 1.5m, yes 1.5m, and it was just a spare, otherwise I had to buy 6m (it's all crazy, I was told it's normal to do everything now in stainless steel). Brass is brass... period.
And then I want to keep everything in the imperial standard. It's more expensive... less a bottle of green.
Bob, it is not a consumption of alcohol, it is a way of saying that a bottle ends quickly, but the piece we see will last longer. I only drink at mealtime, or a beer if it is warmer.
But it looks nice!
PS: Have you see the petter's air filter nut? nice design?
« Reply #138 on: November 25, 2018, 10:41:31 AM »
Hi Pedrosa, yes I saw the new air filter retaining nut, very nice to see someone still knows how to use a knurling tool in a lathe.
sirpedrosa
« Reply #139 on: November 27, 2018, 07:25:14 PM »
Hi Bob
While the restoration does not advance, another brass tap saves from going to the container for china. And it's already polished and tuned.
BR
« Reply #140 on: November 30, 2018, 10:35:55 AM »
I have been performing that same fuel filter conversion for several years, I guess fine minds think alike ;)?
Much easier to do here in the states as we can purchase a 3/8" to 1/4" NPT brass bushing and a 1/4" NPT brass nipple of the correct length at the hardware store. Only place I differ is I place a short spring under the element that serves to hold it up against the head. Somewhere on these pages is a write up if anyone has interest in it. Nice work.
« Last Edit: November 30, 2018, 11:33:19 AM by 38ac »
sirpedrosa
« Reply #141 on: November 30, 2018, 06:33:13 PM »
Hi Butch
I showed your idea in my Reply # 68, and I think it works fine. Bob had doubts about the seal...
Keep in touch.
« Last Edit: November 30, 2018, 06:43:17 PM by sirpedrosa »
« Reply #142 on: November 30, 2018, 07:52:18 PM »
Ah,  I see now. Your element differs slightly from the one I use that has rubber seals that fit tightly on 1/4 pipe. I can find the element number if there is interest in posting it.
« Last Edit: November 30, 2018, 09:53:47 PM by 38ac »
sirpedrosa
« Reply #143 on: November 30, 2018, 11:44:38 PM »
Hello butch
I looked for the filter element that fit inside the wick container, so everything was all inside the body.
And yes it seems to me well that you divulge the reference of the filter element, for each one to adopt the system that they find better.
sirpedrosa
« Reply #144 on: February 07, 2019, 01:07:41 AM »
Hello everyone
Winter is just another month, and I'll see in spring the 12/2 to continue disassembly.
Meanwhile Braim's oil can arrived from the UK on ebay, for the Lister. It's already shining, clean and working.
Let's get going.
BR
sirpedrosa
« Reply #145 on: February 23, 2019, 11:42:50 AM »
Hello everyone
The good weather is coming, the week was working in the village, pruning the trees, especially the olive trees, planting some more with parents and relatives, and...
sirpedrosa
« Reply #146 on: February 23, 2019, 11:44:16 AM »
Finally the 12/2 left the shack. Now I have to disassemble the block to see the whole picture, and check if the account will be reasonable.
Let's see ... and the hydraulic press is almost finished.
Good weekend for all
sirpedrosa
« Reply #147 on: February 27, 2019, 01:28:39 AM »
Hi Everyone
My 12/2 came with a 2 1/4" handle, but does not fit into it, because is too large, so I just restored it to sell.
It's a genuine Lister Handle. Take a look! new ratchet and new grip of exotic wood, and fresh emanel.
sirpedrosa
« Reply #148 on: February 27, 2019, 04:12:14 PM »
Hi Everyone
Does anyone knows what models of Lister have 2 1/4" crankshaft?
Br
sirpedrosa
« Reply #149 on: March 12, 2019, 07:00:48 PM »
Hi Everyone
Today was time to disassemble con rods, to come to the shop to clean and verify clearances. Valve tappets too, only exhaust, because inlet tappets are sized, and need hammer, some heat and lub.
Ps: Crank journal only needs to be soften, it has just signs of being stopped for long time.
