Author Topic: Resurrection of a Lister 12/2  (Read 89316 times)
sirpedrosa
« Reply #165 on: May 26, 2019, 12:32:03 PM »
Hi Butch
Glad to hear from you.
As I said before I couldn't save much green paint, because -  as you can see - most of it are off cause the 20+ years rust, and ATF/Acet.
The red primary is original, and i'll give it another coat of it, not necessarly red - most now are gray.
It will be painted mid brunswick green - as you can see in previous pics most parts are already wrapped in newspaper.
And that pin was really stuck, initially I used the thin steel rod and it began to bend, so I picked the big to take advantage of momentum, and it dropped.
The green paint is custom made with BS code. see my reply here: http://listerengine.com/smf/index.php?topic=8333.msg100163#msg100163
« Last Edit: May 26, 2019, 12:37:30 PM by sirpedrosa »
By order of firing up:
sirpedrosa
« Reply #166 on: May 26, 2019, 03:27:48 PM »
By the way, don't forget to lunch.
Here's a proposal: salmon in the oven with vegetables and sautéed banana.
And, of course, the chilled rosé...
« Reply #167 on: May 26, 2019, 09:28:35 PM »
 That lunch looks great!
I have asked for. mid Brunswick green here in tbe states and all I get is dumb looks
« Reply #168 on: May 26, 2019, 10:33:32 PM »
I found the rustoleum rattle can dark green high heat paint, was a fair match.
 I painted my exhaust pipe wit it to cover up the welding rainbows.  Pipe rarely gets over 320F under full load
sirpedrosa
« Reply #169 on: May 26, 2019, 11:04:57 PM »
Butch,
Please read this site: https://www.bernardoecenarro.com/en/actualidad/detalle/besa-moves-to-bigger-facilities-in-canada.
As far as I can see my MBGreen came from this producer: https://www.bernardoecenarro.com/en/industrial-paint/paint-manufacturers/bind-decoration/satin-urethane-enamel/297.
I request to made it to 170ºC temperature, same as "paragon paints, uk". But as you can see in the site of my supplier (only in pt lang.) but you can see he can customize in RAL, NCS, PANTONE, BRITISH STANDER...
Is that BStandard you want, and you need.
By the way, I noticed the cam lobe of exaust is taller than the intake. What can you tell about?
That's al for now.
PS: take a look at this site also and see the BRITISH STANDARD 381C Colour Chart: https://www.britishstandardcolour.com/
« Last Edit: May 26, 2019, 11:20:58 PM by sirpedrosa »
« Reply #170 on: May 27, 2019, 08:02:36 PM »
The intake and exhaust lobes are different. There was not much issue with lobe wear on the CS. . compare the intakes to each other, same with the exhaust.
sirpedrosa
« Reply #171 on: May 27, 2019, 08:17:19 PM »
Hi Everyone
What you see, is what I got!
The 2 cam lobes of injection pump tappets are "really" pitted.
But the IP's tappet has a roller, so they got to hang on...
sirpedrosa
« Reply #172 on: June 01, 2019, 06:17:06 PM »
Hi Everyone
It works. Yahoooooooooooo! The "anaconda" is out of sump.
First the spanner... making 2 from the price of one.
It was last night 1 AM - there was no time to made a proper lever... To improvise is the word of order.
Pipe wrench with a pipe for leverage to make a angle lever.
It came out. 35 kg of steel snake.
Sump is empty. Now a good clean to start reassemble.
« Last Edit: June 01, 2019, 06:20:47 PM by sirpedrosa »
sirpedrosa
« Reply #173 on: June 01, 2019, 11:23:50 PM »
Hi Everyone
Looking closer to the "anaconda" the journals looks ok, besides some pitting in shaft extent.
But i'm conserned with a sort of metal pattern on the place of flywheels. Please take a look at pics and tell if that is some sort of metal stress.
By the way, cam shaft lobs specs are:
LIP - 48,5 mm
RIP - 49 mm
LIN - 45,75 mm
LEX - 48,5 mm
RIN - 45,95 mm
REX - 48,35 mm
PS: Butch and Bob, don't let me down...
« Reply #174 on: June 03, 2019, 02:30:11 AM »
Just looks like corrosion to me? I assume that area was between the flywheels and seal ring? As to the pump cam pitting I would not be too concerned about it. However if you can source them somewhere for reasonable price replace them.
sirpedrosa
« Reply #175 on: June 03, 2019, 09:16:10 AM »
Many thanks Butch
As I said  before only a few "nuts" like me - and I can't find nomore arround  -  start a sort of passion for this old machines. Therefore, most of them are simply dumped to scrap container, for melting - in perfect run condition...
And for the heartbreaking there is no listeroids, only genuine dursley cast iron.
So, I got to save thoses  cam lobes anyway.
« Last Edit: June 03, 2019, 09:21:13 AM by sirpedrosa »
sirpedrosa
« Reply #176 on: June 03, 2019, 11:51:12 PM »
Hi Everyone
Just passing by to showoff "the" decent wrench lever.
sirpedrosa
« Reply #177 on: July 05, 2019, 12:20:41 PM »
Hi Everyone
This week parts arrived from UK.
Heads and new valves are in VEICOMER to grind seats, and crankshaft and conrods to verify clearences.
Here is the link, take a look  at: https://veicomer.com/en/
« Reply #178 on: July 06, 2019, 11:36:41 AM »
Impressive-looking business
I'm sure it will be good, but I'd be surprised if it was cheap?
sirpedrosa
« Reply #179 on: July 15, 2019, 10:02:34 PM »
Hi Everyone
While the heads are not in order to mount again, the flywheels have come down to paint.
Actually at this time already has the primary.
It remains to do the cleaning and painting of the sump.
This weekend I was promised a few railway sleepers  to seat the Lister.
I think it will be fine on them.
