Author Topic: Resurrection of a Lister 12/2  (Read 89251 times)
sirpedrosa
Re: Resurrection of a Lister 12/2 - more pics
« Reply #225 on: October 12, 2019, 02:40:26 AM »
more 2 pics
By order of firing up:
sirpedrosa
Re: Resurrection of a Lister 12/2 - keystock
« Reply #226 on: October 16, 2019, 10:06:49 PM »
Hi Gentles
Finally keystock arrived at final price of $55. Gold price... but its the only way!
VP
sirpedrosa
Re: Resurrection of a Lister 12/2 - the beast is growing
« Reply #227 on: October 19, 2019, 02:36:58 PM »
Hi All
Making high tech tool to squeeze rings.
2nd coat of MBG on cylinders and heads.
Fitting cylinders down.
snuggling water manifold and intake manifold to get flange aligned (38AC good practice), to torque head down evenly.
I think it will be enough for today.
Nice weekend.
VP
sirpedrosa
Re: Resurrection of a Lister 12/2 - a few more pics
« Reply #228 on: October 19, 2019, 02:37:52 PM »
a few more pics....
sirpedrosa
Re: Resurrection of a Lister 12/2 - torqued and rockers in place
« Reply #229 on: October 20, 2019, 01:35:23 AM »
Hi Gentles
Baskets are almost empty. Head and cylinders torqued - and final clearance rests in 1,3mm. Good figure, just a few thou above max advised.
It starts to look nice... rockers and push rods in place too.
VP
PS: final clearance taken thru injector hole.
« Last Edit: October 20, 2019, 01:41:35 AM by sirpedrosa »
sirpedrosa
« Reply #231 on: October 23, 2019, 12:13:23 AM »
Hi Folks
Small bits are rushing from the basket to the 12/2. Impressive is the minimum I can say.
This afternoon, after sealing governor housing, I saw injection pumps crying to take their place above governor housing - and there they are.
Now I'm expecting they give me a good tip in order to set the sharp timing spill, and get the beast alive.
2 pics for those like more image than rant.
VP
Ps: remember that camshaft IP lobe threded? take look.
« Last Edit: October 23, 2019, 12:15:12 AM by sirpedrosa »
sirpedrosa
Re: Resurrection of a Lister 12/2 - flywhells on
« Reply #232 on: October 23, 2019, 02:07:40 AM »
Hi Gentels
Now it's enlarging. what a beast! My goodness.
VP
saba
« Reply #233 on: October 23, 2019, 03:06:07 AM »
I do not comment a lot on your posts but I am always following. I still have one and a half of these to finish I am jealous of your progress. Looks fantastic can't wait for the video and soundtrack of the first start.
Regards Bernhard
sirpedrosa
Resurrection of a Lister 12/2 - pig tail
« Reply #234 on: November 03, 2019, 03:48:23 PM »
Hi All
All projects are idling (duty far from them), but not fully stopped.
Pig tail is in place. Small bits come slowly from basket, but they will get their place...
VP
sirpedrosa
Re: Resurrection of a Lister 12/2 - Updating
« Reply #235 on: November 04, 2019, 12:11:26 AM »
A few more bits in place.
Injection pipes getting straightened, and water manifolds in place to planning hosing.
Have a good week.
VP
sirpedrosa
Resurrection of a Lister 12/2 - Brass parts for cooling circuit
« Reply #236 on: November 04, 2019, 11:01:06 PM »
What about this idea for cooling circuit?
It only needs the valve gate tap.
PS: I managed to get an old stock faucet to make drain tap.
« Last Edit: November 04, 2019, 11:08:30 PM by sirpedrosa »
sinna42
« Reply #237 on: November 13, 2019, 04:23:34 PM »
Excellent thread ! I've just acquired a Lister CS 12-2 Generator set & am busy stripping down the engine at the moment.
So this thread is of great interest !
Jim
Lister CS 3/1 1938, Lister CS 3/1 1939, Lister H4 Pump, Coventry Victor AN4 Mk1 1944, Gardner 1L2 1962
sirpedrosa
Resurrection of a Lister 12/2 - fuel pump timimg with comparator
« Reply #238 on: November 16, 2019, 04:21:43 PM »
Hi my friends
Today (after 400km) is time to give some TLC to the beast!
Timing injection pumps: pics by order...
1 - setting the probe to the comparator (nothing like a strip of duct tape). This probe - I think - NASA's will never get an ideia of it's origin - ok I disclose, it's a stell strip that holds the visel rubber of a wind shild wiper.
2 - setting the magnetic base of the comparator in place;
3 - setting the magnetic mark in filter to align with the fly rim;
4 - setting the TDC in the comparator;
sirpedrosa
Resurrection of a Lister 12/2 - timing fuel pumps
« Reply #239 on: November 16, 2019, 04:27:05 PM »
5 - mark the TDC in the fly rim;
6 - manual spec by Peter Forbes (RIP)
7 - mark -4.25" = 20º BTDC in the fly rim;
8 - reading the comparator value in mm = 4.25" = 20ºBTDC = -5,25mm BTDC (stroke);
« Last Edit: November 23, 2019, 03:02:18 PM by sirpedrosa »
