Author Topic: Resurrection of a Lister 12/2  (Read 90537 times)
sirpedrosa
« Reply #210 on: September 14, 2019, 11:49:58 PM »
And there were 2 Listers, one 8/1 of 1961, and another 12/2 of 1953.
I felt embarrassed by the description on the board. take a look: the board states 1938, but the serial plate states 1953.
"Anyway, who doesn't know is like who doesn't see!"
VP
« Last Edit: September 15, 2019, 12:58:45 AM by sirpedrosa »
By order of firing up:
dax021
« Reply #211 on: September 15, 2019, 07:14:51 PM »
And I'll bet it never came out of the factory with that air filter either.
sirpedrosa
Re: Resurrection of a Lister 12/2 - Harvesting and new bituminous carpet
« Reply #212 on: September 19, 2019, 10:38:06 PM »
Hi Everyone
Fall season are times to doing crops, and today was grapes crop, starking apples are also mature, and the olives are getting pretty.
Here are some pics of the crop, grape crusher, and one with our work horse a ISEKI 1910 of 1980 (in my hand since day 1).
sirpedrosa
« Reply #213 on: September 19, 2019, 10:38:57 PM »
And also some of the new bituminous carpet.
Stay safe.
VP
Hugh Conway
« Reply #214 on: September 19, 2019, 11:35:06 PM »
@ Sirpedrosa;
Nice harvest! here it's also that time of year. potatoes, onions, garlic tomatoes, apples, pears, peaches, and even some grapes. An apparently smaller garden than yours, but it really keeps us busy. No tractor, just hand work.
A new driveway is awaiting......... A dumper brought yards of gravel two days ago. Now it needs to be spread......wheelbarrow, shovel and rake. Wish I did have a tractor, but.......
Hugh
1963 BMW R-27 project
sirpedrosa
« Reply #215 on: September 20, 2019, 12:20:45 AM »
Hi Hugh
That is in the village... because nearby my home in city (left bank of tagus) is also all by hand, but it's only to "exercise the laziness".
By the way please tell if you know where this company: http://catalog.daemar.com/item/dmr-trade-keystock/rectangular-keystock/0-313-563-12
If so, let me know.
VP
« Last Edit: September 20, 2019, 11:17:58 AM by sirpedrosa »
sirpedrosa
Re: Resurrection of a Lister 12/2 - HEADS READY
« Reply #216 on: September 21, 2019, 02:33:27 AM »
Hi Everyone
New valves seated, heads skimmed, measures taken and cylinders top sanded.
Next task: cutting joints to main bushes, and start putting parts in place.
Have a safe day.
VP
Hugh Conway
« Reply #217 on: September 21, 2019, 03:58:08 AM »
@ sirpedrosa
Daemar, the company you asked about has Canada locations in Toronto, Montreal, Edmonton, and Vancouver.
Vancouver is closest to me, but still a few hundred miles and 3 ferry rides from here. Also in USA
Looks like a good source of bushings, keystock, shims, etc.
Hugh
sirpedrosa
« Reply #218 on: September 22, 2019, 12:16:40 AM »
Hi Everyone
Some more improvements today, cutting a bunch of joints to fit main bushes, fit felt washer, and tuning crank shaft end play.
Fitting idler gear - marked inside, as well as camshaft and crank pinion, so we can time it from inside.
Some pics, for the enthusiast.
VP
sirpedrosa
« Reply #219 on: September 22, 2019, 12:29:39 AM »
And final product... for today
PS: By the way, shop charge me with 250€ for valve seats and head skiming.
« Last Edit: September 22, 2019, 10:30:14 AM by sirpedrosa »
sirpedrosa
Re: Resurrection of a Lister 12/2 - tightening central main bearing
« Reply #220 on: September 30, 2019, 08:16:40 PM »
Hi All
Nothing like a sweaty evening to tighten the central bearing of the shaft.
Some pics for enthusiasts.
Cheers.
VP
PS: remember wrench lever I made before?
sirpedrosa
Resurrection of a Lister 12/2 - one more visit to the beast
« Reply #221 on: October 01, 2019, 01:39:37 AM »
Hi Gentle
Who can confirm to me the torque of the main bushing nuts.
I found this table: http://www.oldengine.org/members/diesel/Articles/rrchapt8.htm
But I think the values are tabulated for R-grade, and the original studs should not be R-grade, because the torque wrench was already 60ftlbs, and I don't think they could handle 70ftlbs.
Well, the connecting rods are already in place too ...
VP
sirpedrosa
« Reply #222 on: October 01, 2019, 11:59:03 PM »
Hi Gentle
Some more steps.
Con rods are in place and torqued.
Oil manifold too. Take a look at blind snuggle and tighten of oil delivery pipe! It's not easy with that french wrench!
Be happy
VP
sirpedrosa
« Reply #223 on: October 04, 2019, 08:02:26 PM »
Hi Gentles
the "greeny" is growing.
Straightened oil pipes (I mean more curved) and starting to set bump clearance.
VP
sirpedrosa
Re: Resurrection of a Lister 12/2 - the beast is getting up
« Reply #224 on: October 12, 2019, 02:39:31 AM »
Hi All
Some more twiking in the beast, fit cylinder joints to set height, tin to set bump clearance, ready to torque.
Loosening nuts and measuring clearance.
Now I got to do math.
Have a good weekend
VP
