Hi Guys
I know folks on here love to share their experience, and I'm interested in improving my thinking on inverters . . .
Firstly let me say I have been re-reading Starfire's excellent post and subsequent responses. See link below:
http://listerengine.com/smf/index.php?topic=7460.msg84365#msg84365I'm a big KISS fan. I used to enjoy having cars with points ignitions and carburettors cos I could see how everything worked and diagnose a fault in 5 mins flat - but I have gotten over that particular Ludditery and these days have a couple of $1000 2.2-litre Toyota Camrys as they are the philosophical equivalent and may well outlast me
I'd like to own an inverter like the Camry - tough, simple, good, over-engineered and under-stressed . . .
The gentleman who has been advising me on solar stuff - and whose advice I have found to be good - suggests that the modern combination of inverter & charge controllers are the "way to go"
He is recommending this unit:
https://www.victronenergy.com/inverter-charger-mppt/easysolarBut I could just as easily buy whatever I can find that is a super-robust charge-controller and do things like managing charging/voltage myself, and maybe run two or three small inverters
Typically my households use bugger-all current as I tend not to have anything with an electric element apart from an electric blanket and a small toaster. My norm/current setup is: solar hot water, woodstove, wetback, gas hob, low-output microwave, spring-fed water so no pumps etc etc - a familiar picture I am sure
I am attracted to the Outback inverters
I have a couple of 230V gen heads as works-in-progress and hope to be in a situation where one or other of the two CSs can be either putting 24VDC back into a battery bank and/or generating a few kWs AC if I need to run the small welder or the angle grinder
I'd be interested on thoughts on inverters and on modern complex/sophisticated equipment like the Victron units vs something heavy and simple with a big copper transformer and a steel frame and two big handles kind-of-setup
I have a couple of quiet, (one genuine Honda, one cheap Chinese) 2.4 kW generators with 15-litre tanks that can idle inaudibly all night if need be, plus a big 5kVA genset that can run the fast-acting 3.6kW 60-litre hot-water cylinder as a convenience if the sun isn't shining, the fire hasn't been going and herself wants a shower NOW . . . so no real need for a big-current inverter. If I had just one unit (instead of a few small ones) it'd be a 1500/2000W job, I would say
I don't reckon I give a rat's about pure sine either. Everything I own seems to run OK on a dirty square wave with a few corners clipped off and, in my luddite-ish way I figure cos the laptop runs off of a 19.5V (DC I assume) charger thingie, it probably doesn't care if the VAC going into it is a bit dirty? Since I am blessed to not own a TV I don't care about that either
I might put a search on TradeMe (think ebay/gumtree) for small inverters and get an idea of what sells for what $$
Enough from me - this is turning into a Glort-length rant
I'd appreciate any thoughts
Cheers, Mike
