Author Topic: 6/1 and 3.5/1  (Read 4445 times)
6/1 and 3.5/1
« on: July 28, 2018, 06:41:54 AM »
Hey there experts & knowledgeable folks . . .
I have a couple of 6/1s, but also the bottom end of a 3.5/1 in the yard as well (I gave the barrel and heads to some bloke for his one)
The 3.5/1 piston is a bit lighter, I guess, so maybe the counter-weights on the wheels are different - does anyone have any experience around the interchangeability or otherwise of these, I wonder?
What started this train of thought is that the mains are probably the same bolt-hole pattern so the case could be a donor "spare", cleaner-upper for one of my 6/1s
Then I started wondering about the crank . . . am I right in thinking maybe there were two sizes journals of 3/1 big-ends and maybe (a later?) one is the same dimension as the 6/1?  Or maybe that's wishful thinking?  What excited me there is one of my 6/1s has buggered Gib keys with the heads snapped-off and is going to be challenging one day; but the 3/1 bottom end has good-looking keyways and gibs
Apart from all that, it seemed to me that if you took the 3/1 wheels off and put them on an axle in a pair of rollers and cut off the balance weights carefully until they were "neutral" balance-wise; you could just about run two flywheels on both sides of one of the 6/1s as an experiment in rotating-mass and anti-flickering and stuff like that?  (After all, the one with the buggered gib keys is never going to want to yield its flywheels so I could trim what little is left of the heads of the gibs back to nothing without being any worse off - and snug-up another pair of flywheels
Just an idle thought-train of a cold Saturday evening with the fire going and peace-and-quiet here to allow the brain to wander . . .
EdDee
Re: 6/1 and 3.5/1
« Reply #1 on: July 28, 2018, 07:54:01 AM »
Hey Mike...
The double flywheel setup works very well.... My APC UPS's wouldn't sync to my 12/1 when i ran below about 700 rpm.... I neutral balanced a spare set of scrap quality flywheels after a thorough checking and installed them as close to the crankcase as I could... Even  notched the heads of the inner set of gib keys to get the gap to less than half inch... The nett result is pretty much flicker free running at to below 500 rpm...And the ups's sync nicely too...
It works well indeed... when you get to below the 500 mark, it is sometimes needed to retard the injection slightly to lessen the knock and jerk... this was mainly for ups syncing. Above 500 and it makes little difference... If i remember correctly, my double wheeler is running about 550 rpm with no ill effect as yet... it pushes 4kw with reasonable ease and is pleasant sounding to boot...
Regds
Ed
Re: 6/1 and 3.5/1
« Reply #2 on: July 28, 2018, 08:01:54 AM »
Thanks, Ed.  I have a project I'd like to run the #2 CS at about 580 rpm under about 3kW load - so that sounds hopeful.  Cheers
listard-jp2
Re: 6/1 and 3.5/1
« Reply #3 on: July 28, 2018, 08:20:50 AM »
The 3.5/1 crank is identical to the 6/1 crank, in that it will have the 2.1/2" diameter big end journal diameter. It is the earlier 3/1 engines that are not inter-changeable as they will have the 2.1/4" journal diameter and will use the thick wall bronze backed shell bearings.
However having said that the 3/1 crankshaft is also inter-changeable with early 5/1 engines.
Re: 6/1 and 3.5/1
« Reply #4 on: July 28, 2018, 12:38:43 PM »
Hi Mike.
I have a 3.5, 6, 8/1 bitsa
The 'plate says it started life in the early '30's as a 3.5/1 hopper cooled, when it got to me it had a 6/1 top end.
Someone had poured sand in the crank case, honest!, and then it had been topped up with grease, I pulled it completely to pieces and boiled the crankcase and sundry bits in a 40 gallon barrel with a couple of kilos of caustic soda and started again.
The mains and big end were wrecked, so, having had the big end reground to suit a hugely undersized Rajkot bearing I eventually I fitted taper roller bearings, with plenty of Loctite (620, I think).
It was massively out of balance (I did the Butch bucket and string test but can't remember the details, they're on one of my previous posts, I think) so I sent off for a Rajkot 8/1 Aluminium piston. With no other counter weights it runs like a Swiss clock, well nearly!
There's a massive difference in weight between the iron and the allu pistons, again I can't remember how much, 25%?, maybe I should document more.......
Here's a link I've posted before, of it pulling 2.3 KVA
https://www.youtube.com/watch?v=js3zz6CECqY
It starts to get excitable around 675 rpm, so hopefully, when it goes into off grid duty, at around 625 rpm, in the next couple of years or so, it'll be fairly long lived.
Cheers Stef
Re: 6/1 and 3.5/1
« Reply #5 on: July 28, 2018, 05:09:02 PM »
Steph, thanks very much
That's an absolute beauty - especially the finish
I hadn't considered the alloy piston as an option - but I guess with such a "cold" engine their durability is good
(the 3.5/1 came with some random English truck piston fitted, and it had run on-and-off for years like that.  The guy I bought it off was in his '30s maybe, and his grandfather had fitted it "years ago")
Is there a body of experience/school of thought around the longevity of the alloy pistons?
Re: 6/1 and 3.5/1
« Reply #6 on: July 29, 2018, 09:34:58 AM »
Well done Stef, what a beautiful piece of machinery, an absolute credit to you and your skill and perseverance. Loved the video well done with the star wars style intro.
Can`t wait to get back to my rebuild, I`m going to collect a new 5KVA generator head next weekend. Wish I could afford a Stamford, even second hand. I had to settle for a cheap Chinese made ST head. I`ve ordered some decent bearings for it and will true up the slip rings on the lathe before putting it into service.
I`m with Glort on the quality of out buildings in France, I`ve been planning to build in stone but finding the time and energy is a struggle, even with the stone just lying about in the fields waiting to be used.
Re: 6/1 and 3.5/1
« Reply #7 on: July 29, 2018, 09:45:15 AM »
Hi Glort
You'd love a mate of mine, Sylvain, he's the leader of the local hunt and an ultra keen wildlife photographer
https://www.google.fr/maps/uv?hl=en&pb=!1s0x12a839137cdc5c81:0xded2a09f835974bc!2m22!2m2!1i80!2i80!3m1!2i20!16m16!1b1!2m2!1m1!1e1!2m2!1m1!1e3!2m2!1m1!1e5!2m2!1m1!1e4!2m2!1m1!1e6!3m1!7e115!4shttps://lh5.googleusercontent.com/p/AF1QipO6v-UsMwbwh3xzpsnNVmr-91h2F2JhuLIlhAV8%3Dw375-h250-k-no!5ssylvane+de+payolle+-+Google+Search&imagekey=!1e10!2sAF1QipO6v-UsMwbwh3xzpsnNVmr-91h2F2JhuLIlhAV8&sa=X&ved=2ahUKEwidp4jv8sPcAhVNzRoKHSJhBesQoiowCnoECAoQCQ
A bit of a long link but I'm not too computer literate!
He spends hours up in the hills and is fascinated with all aspects of life up here , for ther first time, this year hehas an exhibition in a local bar.
For photo's of us look up Chalet Tourmalet on Booking.com, most of them were taken by my other half. For something stunning in real time, assuming decent weather conditions, check this out,
 http://picdumidi.com/fr/live-conditions/panoramique
It's about 5 miles from here, as the crow flies. it's live and sometimes the sunsets are awesome. We get all of our media via an android box and the internet, when we have guests we use it as a screensaver whilst the radio is playing through the tv.
Not sure if this counts as 'guerrilla advertising'. Ade, you can delete the first couple of paragraphs if it crosses the line!
Why not get the 3/1 and scrounge around for the bits to change the top end? At the worst way you could order a barrel, ally piston, rings ect from Rajkot, I don't know if the head is the same, I believe there's a difference in the rocker arrangement but if the cylinders fit the stud pattern then there's a good chance it will go, someone please correct me if I'm wrong.
You wouldn't damage anything, so in the - very unlikely - event of them becoming the collectors piece they deserve to be, your investment would be safe!
Cheers Stef
listard-jp2
Re: 6/1 and 3.5/1
« Reply #8 on: July 29, 2018, 09:49:22 AM »
If we are talking about OEM pistons, then the weights will be:
Cast Iron piston 4.5 Kg
Aluminium piston 2.5 Kg
However from what I have seen of Indian versions of the CI piston, it's going to be slightly heavier, as the piston casting is somewhat more crude, with more material in the lower skirt area of the piston.
Re: 6/1 and 3.5/1
« Reply #9 on: July 29, 2018, 10:28:40 AM »
Hi Listard.
The flywheels would, I presume (always dangerous, a little presumption!) be weighted for the smaller piston of the 3/1 so the difference in weight (3/1 iron piston versus 6/1 ally piston) would not be quite as dramatic.
I did, whilst rebuilding my bitza, ask on here if any one knew of the difference in the cast in counterweights of the 3/1, and 6/1 (and by extension 8/1) but don't recall seeing an answer.
Cheers Stef
Re: 6/1 and 3.5/1
« Reply #10 on: July 29, 2018, 11:01:23 AM »
Hi Bob
Thanks for the 'chuck up', it's not all it seems, I made most of the standard cock ups on the way, but at least I overcame my fear of stripping down injectors and pumps!
The paint came out of aerosol cans from Lidl's (a Europe wide chain of supermarkets that have 'specials' every few weeks designed to appeal to blokes─ every thing from spray paint to chainsaw sharpeners) I always have a few cans around for brackets of what ever else I'm knocking up, and when they came aroundas I started the CS the green was almost a dead ringer so I banged a dozen into the weekly shopping trolley, much to the surprise of the Mrs!, it seems to be as durable a 'Smoothrite' and around 3€ a pop. I'm down to the last can now and waiting for them to come around again.......
The Star Wars theme was my mates idea, I did read on here that the rebuild is not complete until you've put up a video, I'm a self confessed technophobe, so my mate volunteered but went a bit wild with the artistic content!!
Don't get too carried away with the 'quality' of French barns, it's got no foundations and the level is almost half a meter different from any two opposite corners, that having been said, it's stood for a couple centuries, half way up a range of mountains that are being buggered about by the tectonic plates that trying to shove Spain into France, with an earthquake every few months, it must be doing ok!
Cheers Stef
Re: 6/1 and 3.5/1
« Reply #11 on: July 29, 2018, 04:55:49 PM »
The Rajkot aluminum alloy piston in my neighbor's 8/1 from DES looked like a good job of casting and machining.  If your Listeroid is a hopper it can only help, significantly.  Note that the rings aren't all the same as the cast iron piston, so plan on getting a ring set for it.
Re: 6/1 and 3.5/1
« Reply #12 on: July 29, 2018, 10:13:32 PM »
Hey Glort, if you still want a CS have a look at this, https://www.gumtree.com.au/s-ad/petrie/other-antiques-art-collectables/lister-cs-diesel-vintage-stationary-engines-x-8-from-200-each/1191047222
Lister diesel porn, only risk one eye or you`ll go blind. Priced to sell from the look of it.
Re: 6/1 and 3.5/1
« Reply #13 on: July 30, 2018, 01:53:18 AM »
Petrie Qld I would guess is Rob at Oldtimer Engines?
FWIW just to put it into perspective, I checked out freight from NZ - US last week just out of curiosity and it's probably $NZ500-plus for an engine, sea freight.  I would think NZ-AUS would be cheaper but not necessarily lots cheaper?
"Buy local" might be the lesson
I wonder why Rob would be selling these - and, potentially so cheap
Re: 6/1 and 3.5/1
« Reply #14 on: July 30, 2018, 08:59:39 AM »
Hi Guys, yes it`s Rob at Old Timer Engines. No idea why he is selling so many and it does say "starting at $200". He has been collecting for years and is also one of the only spares suppliers in Australia, perhaps he is selling engines knowing that buyers will then spend a sh1t load more money restoring them. Good luck to him.  :)
Wonder if he`s got a twin cylinder CS for sensible money, unlike this guy who must be smoking too much home grown: https://www.gumtree.com.au/s-ad/new-beith/miscellaneous-goods/lister-12-2-diesel-twin-cylinder-engine/1190994580
$5,500! must have gold plated pistons & platinum rings.
