Author Topic: micro-vee PK pulleys  (Read 1621 times)
« on: July 26, 2018, 10:12:42 PM »
Here you go Glort
I forget how people got onto the subject of micro-vee pulleys, but this is the driven pulley for my 3000 RPM head off the 24” wheel of the CS (should run no-load 3150 at 580 engine RPM if my count-on-the-fingers is right)
It’s the aircon pulley off a big truck.  I went to the local truck wreckers with a pair of vernier callipers and checked out the pulleys on lots of engines until I found one close to perfect
There were lots of those 8PK pulleys of all sorts of diameters from 250mm downwards driving water pumps and power-steering pumps and some quite big-load sort of truck stuff
This one had a clutch in the centre as it was an aircon pulley and I cut that out and filed the stubs of the lugs out of the way
I just cut a bit of M16 plate into a circle, welded it onto the end of a bit of 40mm shaft, got the local machinist to turn it to 107mm to suit the I/D of the pulley and face-up the back of it square
Tacked the pulley in place using the thumbnail-ometer to get it flush and gave it a trial spin on the lathe to check it for true – it came up primo.
$80 for the pulley and $20 for the machinist
