Author Topic: petter ac2w  (Read 3443 times)
Aka1974
petter ac2w
« on: July 15, 2018, 05:08:21 PM »
Hi
I have just joined after finding this great little site.
I'm looked for some help and advice concerning my ac2w engine fitted to my narrowboat.
Ok so she starts easily but seem to have a fuelling issue
Once started and set to tick over and seems fine but the tick over can be erratic drop off a few rpm then picking up again. But the real issue starts when you increase the revs and run at higher speed for a while all seems ok but if you return to tick over and either cuts out of struggles to tickover.
The problem seems to get worse generally the longer the engine has been running. Also power at speed seems to drop off to.
I have recently replaced fuel lines and filter and put on a new four bolt lift pump as there was only the 2 bolt one fitted. But it has had no effect on the problem.
Any advice help appreciate. Or even better if there's a good mechanic on here who knows these engines i will happily pay for your services. I'm in the Leicester area
Aka1974
Re: petter ac2w
« Reply #1 on: July 16, 2018, 06:02:30 AM »
Hi
Ok thanks for that i will try them ideas at weekend
Altonx
Re: petter ac2w
« Reply #2 on: August 20, 2023, 10:48:38 PM »
Did this get resolved?
I have the same issue with my AC2W, be interesting to know the outcome
