This one has always made me laugh, turning off lights because they use power and send the bill up.
Even in the good old days when I was a kid, my grandmother would get real annoyed if you left a light on in a room you weren't in. At 15 years old I was pointing out the amount of power her 2 bar radiator she sat over all winter used in comparison to the incandescent light bulbs she was so fanatical about.
It fell on deaf ears.
Maybe it rubbed off a bit on me after all because I have always been the same with leaving lights on even though I realise the real insignificance of them in the over all power use of a modern home. When we came here I replaced a lot of the old bulbs with the CFC things my wife bought. Some were OK, some were crap. They were a lot lower in power use and that was getting to me the way my daughter thinks a light switch only works one way.... ON!
I have turned around now with my lighting anxiety and am now turning them on just for effect.
Couple of weeks ago Mrs and I went out and bought a heap of new Decorative light fittings. Some of the ones that were here must have been brought from another house because this place wasn't near around in the '70s which was the era of some of the fixtures.
I got up in the roof and installed the new Fittings and moved some around to better locations. We got a really great antique looking double shade piece that I centered over the dining room table rather than in the centre of the room. Looks awesome. Wiring in the roof wasn't too my liking, typical get it done to the min standard to pass requirements and on to the next job so I fixed a lot of that to my satisfaction while I was up there.
By sheer luck, I went to the hardware for some globes and they are having their EOFY clearances. On a big mobile rack up the back were a load of Light globes. Just what I freaking wanted when I wanted it, for once.
They were all pretty much LED except for a couple of the very old yellow decorative filament style I grabbed a couple of for some lamps we got. At 25W they are low powered by the old standards but like grans old radiator in comparison to the new ones.
I got a bunch of normal looking LED bulbs. They LOOK like lightbulbs, not Giant glow worms that had an epeliptic fit and contorted themselves into a grotesque shape that can't be installed in a lot of regular fittings.
They are 4W. I thought these aren't going to do much but will be OK for a few things.
Put them in and stuff me! these things are Bright and throw a heap of Illumination out! I went round and replaced some CFC's and incandescent and it was a great improvement in the quality of light aside from the power reduction. I got these huge round style Bulbs which are LED for over the table and they look awesome. Very authentic and period.
Lucky there is a dimmer for them because they need to be turned down for effect as they are too bright at full tilt.
I as so impressed with all these globes I went back and bought a Heap of them in different sizes and shades as well as styles. The prices were giveaway cheap so I stocked up while the going was good which is kinda ironic as with the life of these things, they will probably well outlast me!
The comparison of consumption to the old globes is amazing.
There were a bunch of spotlights on the back verandah. Horrid stark things that used these halogen Pin base globes. I replaced them with some Coachlight fittings I bought which look so much better and go with the style of the house as well as throwing a much more appropriate specularity of light.
The old Fittings were all double's with 2x 50W globes ea, 300W in total. I put the coach lights up and threw in the LED bulbs without thinking much about them.
Tried them that Night and thought geez, might have to put a dimmer in here, these things are bright and I used the low power ones I got. Had a look at them and they draw 6W ea! 18W in 3 Fittings from 300W and I gaurantee the light output is higher!
That was just the start. Went and did all the lights along the driveway and across the front. Did the coachlights on the front verandah as well. Each light had a 60W bulb. Replaced them with 3.5W bulbs and the things are Brighter still. The muther of a tree out the front had spotlights under it, 3x100W ea.
Replaced them with some 10W outdoor floods I bought a while back on fleabay and the old tree is brighter than ever.
The front was up around a Kilowatt with everything on, now it's well under 100W and brighter than ever. Already had a compliment from the neighbour across the road how good it all looks.
I put the lights on now for when the Mrs comes home. She loves to see the place lit up after a day at the kindergar... office and it's just a little thing that makes her feel content. I used to hate putting them all on even though I knew they were using nothing relatively, old ingrained habits I guess, but Now I put them on front and back to show off. Neighbors probably think we are rich running all these lights but I literally would spend a fraction on them ( even without solar) that I spend on boiling the kettle every day. I might look at putting them on My Christmas light type Timer I built.
Turns on at dusk, runs for 4 or however many hours I program it then switches off.
The biggest light in the house now is a 35W CFC here in the office that I use for colour balancing but it's really a shit light for everything else. When I was at the hardware they had these Solar/ rechargeable LED work lights going cheap. bought one and brought it home and it's a ripper. Went back to get a half dozen but they were all gone. I am actually using that light atm for balancing and it's far better than the other CFC. I think it only has a single 18650 battery but I'll pull it apart and see if I can't put in a few more in parallel. It runs 6 hours on one panel and 3 with both. Solar charge component as usual is a joke, Supposed to take 18 hours of sunlight to fully recharge. I have a small 12V panel I'll put a plug onto and at 10W should charge the thing even with more batteries in a far more timely manner.
I do have a 100W LED flood for out the back that lights up the whole half acre of back yard and a couple of smaller 50W floods on sensors in front of the shed and along the back path.
The only incandescent I haven't changed are some GU10's on the other side of the back verandah. There are a dozen of them in light bar like fittings. I couldn't find anything cheaper in LED to replace them than $5ea so they can stay. Only be used when we are out there occasionally for BBQ's etc and now with the others, won't be much need to use them at all. Cost me about 100X more to replace them than they will burn in power in the next 20 years anyway. I Might swap them out for LED Floodlights I have and point them up into the roof for a better ambient light.
I always think of my grandmother with LED Torches/ flashlights. She had this old torch that ran on a couple of D size Cells that was good for about 10 Min before it went dim. With her Nightly visits to the outhouse, that 10 min came round fast. I look at my collection of LED's now and the light they put out for hours and always think how amazed and happy she would have been to have one. the fact they are all on rechargeable batteries would be even more amazing to her. Probably would have complained about being too bright instead of too dim.
Would have never been able to make her understand that every light in the place running 24/7 would probably add about $2 a week to the power bill.
Of course gran would be 108 now, a lot of things would take a LOT of explaining to her.
I find Old Ideas take at least 30 years to fade away so I Imagine people will still be talking about turning lights off to save power for some time to come yet..... as they sit in front of their 75" Tv's or have them going just for the noise when doing other things around the house.
