a thought
filter the oil with a screen to get the rocks, feathers and frenchfries out
cut it with diesel to thin it a bit
filter it again to 5 microns or maybe then to 2 microns
then run it thru activated charcoal to get the extremely fine particles out?
i watched a history channel show the other night, modern marvels or whatever
they were showing how activated charcoal takes the color out of some sort of alcohol or solvent that was blue
now if it can take the blue out, perhaps it can take the black out of oil?
there are many grades of activated charcoal available, finding the right grade might be a trial and error proposition
but i wonder if it might just work.
many years ago i watched a program on how they get diamonds seperated from the dirt and gravel after the rock was crushed
they slurry the crushed with water and run it over a board trough that is heavily coated in grease.
the diamonds being carbon will stick in the grease and everything else does not, water and sand just wash right over
the point being carbon sticks to wet grease, the black in waste oil is carbon
now we can't run oil over grease without it dissolving the grease, but
oil doesn't as far as i know dissolve activated carbon, so perhaps the sub micron carbon in the oil might adhere
and be caught in the activated charcoal just as the blue color did in the history channel program.
personally i think it might be worth checking into and running some small scale testing
the waste or spent activated charcoal should be able to be used to burn for heat i would think as a means of disposal
so maybe a multistep
and use the fullers earth as one of the steps as well
a final pass through a luberfiner 750 filter would then polish the stock to high enough quality to be used as a fuel
and my thinking is it would probably be cleaner than what one gets at the average pump on most days.
