Author Topic: 2 kW generator head  (Read 6087 times)
Re: 2 kW generator head
« Reply #15 on: June 03, 2018, 07:44:58 PM »
Then there is this method that was mentioned here on LEF in a different thread. Looks like an inexpensive way to go.
https://www.youtube.com/watch?v=Se6ceGegUYQ
Also this http://www.utterpower.com/a-free-diyer-generator-head/
Worth a look anyway!
Hugh
I saw this a few months ago and I actually checked and you can buy a 4 bolt pillow bearing that lines up perfectly with the holes in the alternator end casing The bearing should be the same size as the shaft too . A taper lock pulley and Robert's your mothers brother
Hugh Conway
« Reply #16 on: June 03, 2018, 09:45:46 PM »
Johndoh, might you have a contact for that adapter?
Good information to have!
Hugh
1963 BMW R-27 project
« Reply #17 on: June 03, 2018, 09:53:11 PM »
Hugh
It's just a standard pillow block bearing if you're in the UK you can buy imperial or metric sizes.
https://www.ebay.co.uk/itm/UCF204-20mm-Mounted-Bearings-4-Bolt-Square-Flange-Pillow-Block-Bearing-Housing/122687376627?var=&hash=item1c90bcccf3
« Reply #18 on: June 03, 2018, 10:53:20 PM »
Mr Hanglands is a very useful mammal. Love his outside the box thinking.
