Author Topic: When previous owner had a pulley on the shaft & REALLY didn't want it coming off  (Read 419 times)
Resorted to my four old friends:
Cutting disc.  Heat.  INOX.  Force
Was it welded on?
I bought some gear pumps once all with taper lock pulleys....  very securely welded on.
Looks to me like the key has spun on the shaft. You wouldn`t believe that this was possible but when an irresistible force meets an immovable object something has to give. I`ve seen many shafts on reduction gearboxes with similar issues.
Well done for getting it off without too much damage.
