Author Topic: AD1 engine oil  (Read 1541 times)
johnnyG
AD1 engine oil
« on: April 28, 2018, 12:57:51 PM »
Hello and good day folks, I have recently bought a New (Old stock) AD1 which is up and running fine, small problem is, whereas the oil level is fine and the oil which is light green in colour is clear. I don't know what the oil is so would like to drain it and fill with new oil.
What is the recommended oil for this machine please.
Any advice welcome.
thanks
john
Re: AD1 engine oil
« Reply #1 on: April 28, 2018, 04:12:30 PM »
Lister recommended a range from 5w-20 to 20w-40 depending on temperature. 10w-30 and 15w-40 are right in the middle of their recommendation.
Here is a link to the operators manual. http://www.winget.co.uk/document/LISTER%20PETTER%20AC-AD%20OPERATORS%20MANUAL.pdf
It is noted in the manual that Lister supplied the engines with break-in oil that should be changed @100 hours. That is likely the oil you are seeing based on it being a NOS engine.
« Last Edit: April 28, 2018, 04:14:31 PM by broncodriver99 »
johnnyG
Re: AD1 engine oil
« Reply #2 on: April 28, 2018, 07:02:57 PM »
Hello again, many thanks for the replies so far.
The chap at my local motor factors has strongly advised i use 15w-40 mineral oil.
As opposed to synthetic or semi synthetic.
Would anyone concur with this.
thanks again
john
Re: AD1 engine oil
« Reply #3 on: April 29, 2018, 12:25:46 AM »
Until the engine is broke in, only use mineral oil.
And I would change it BEFORE you run it.  30+ year old break-in oil, could be so bad, it could break the engine. Who knows what vintage oil exposed to atmosphere, is like.   I'd run it with $3 qt grocery store oil for an hour, and change it, think of it as a rinse to get the old oil out of there.
