All this talk of engine rebuilds and therapy and interesting pics..... Got me motivated again to drag out the jackhammer and give her a fire up.
Crank handle and a couple of bits arrived this morning from Old timer engines wrapped up like I have never had anything wrapped before. To say secure would be a gross understatement. Literally took me 5 min with a sharp knife to unearth my newest oily treasures.
Spend some time mucking round trying to get the thing mibile on some wheeled trolleys then came across some 6" castor wheels so lifted the thing up high and screed them on underneath the hardwood bearers it's sitting on. Quite a feeling working underneath something swinging around like that.
Told the Mrs those 1 ton 2m lifting slings they had on special would come in handy the other week and I was right yet again!
With nothing more then the old bio still in the line from it's last fire up about 3 - 3.5 years ago, I tested the fit of the handle which was secure but very free, did the mental practice of the motions, wondered if I was going the right way and spun her up.
Fuel was on, dropped the compression lever and it self sustained almost silently... which was a new thing. Couldn't hear it firing but there was a feint smoke and the thing wasn't slowing down even if it weren't speeding up. after probably a good 10 sec she fired audibly, repeated and gained speed.... and jackhammer motion. We made good Bio my mate and I! Don't have any oil atm so the poor thing will have to suffer that Diesel junk. I'll put plenty of 2 stroke in it to make it more palatable and find some oil on the weekend for it.
I had already put 120G of wheel weights on each flywheel where the weight is cast in and the thing was clearly yawing fore and aft with the same sort of exuberance I remembered. Ran it till she settled and shut it off hoping it wasn't going to fall over on the wind down.
Added another 60G of weight to what I thought was the light side, 2nd spin up and immediately observed I got that wrong.
Removed added weight and put it on other side. Wouldn't fire and saw the old hardened fuel line had broke off at the filter barb so came in for a couple of the largest glasses of ice water we have soaking in sweat and to inform the world of my major breakthrough for the day.
Wondering now if I did the right thing with the wheels. Don't have too much time to spend on this right now before my daughters 21st party next weekend and I figured If I just sit the thing in the garden/ dirt it should settle or rock around as it wants. If it settles on the wheels I may never get it out with the mower. Spose I can drag it out with the car. Might have been better just to put it on skids and slide it across the lawn?
I'll give it a few more windups after I put some fuel line on it and see if I can find one of the couple of fuel pumps I know I have somewhere unpacked or I'll just have to hang a jerry can out of a tree to feed it. I'll play with the weights a bit and see how I go. wasn't successful last time but I'll also try that balancing app I downloaded a couple of years back. Not sure how that will go but can't hurt it it don't help.
Ordered some old coach light lamps the other day and some of those trendy old time LED bulbs. Going to make a lamp post Out of some big steel I have and have the roid running that through and inverter off the 2x 12V alternators I have on the thing. Probably won't get any lister flicker which would look good in this case.
More more work, time and effort I'm not really up to atm but it's all you guys fault for the inspiration and motivation.
First lot I have had in a couple of years so can't complain I spose.
