Hi Lister Forum,
I'm a newbie on the site. I am presently Working on several Lister projects. My Jkson 2/12 is almost ready to fire up and will be coupled to an induction motor for asynchronous generation and used vegetable oil.
I have a SR1 which requires a replacement generator head. Does anyone know of an 1800 rpm direct coupled unit in the 3 kw range? My backup plan is to use an induction motor.
My Lister 1800 rpm SR3 has an 8 kw Winco generator head. It seems a little small given the engine capacity. I was thinking to swap in a 10 - 11 kw direct coupled head. Are the Stanford clone generators reliable? Is the Stanford design the most efficient generator head available? What kind of voltage regulation does a Stanford require?
Has anyone done WVO feed on a SR3?
Thanks,
Neil
