Author Topic: Jabsco water pump  (Read 370 times)
ygododdin
Jabsco water pump
« on: November 01, 2017, 06:52:10 PM »
Hi I've got an sr3 with a Jabsco water pump fitted.  The pump has recently started leaking from where the flange is bolted to the engine block.  Is the pump knackered and can it be repaired?  I hope so because a replacement is over 280.
Your help would be appreciated.
32 coupe
  • "Doc Johnson" on call !
Re: Jabsco water pump
« Reply #1 on: November 01, 2017, 08:44:42 PM »
In a boat ?
Jabsco pumps are easy to rebuild with kits readily available.
The ceramic seal is usually what will leak.
I would be willing to bet you could find a utube video on how to do it.
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
« Reply #2 on: November 02, 2017, 02:17:48 AM »
I have several Jabscos. Great pump. You can buy anything and everything for them. Not cheap but at least you can get what you need.
Blue
« Reply #3 on: December 01, 2017, 01:33:03 PM »
Only pain with them is stripping the cooler to remove all the bits of broken impeller after it breaks up. >:(
Blue
Owned; Lister ST1, ST2, JP4, LD1 & 2x Blackstone ERS8. Petter AA1, AC2 and still up for it !!!
