Author Topic: hello  (Read 3024 times)
Debbie
hello
« on: October 16, 2017, 01:52:13 PM »
Hi, this is just a quick hello from a new member. Hi  :D
I have a lister engine in my narrowboat. unfortunately I am not 100% sure which type it is.  :-[
I have looked at the pictures on the realdiesel website and the one it looks like the most is Lister Petter TS2M Twin Cylinder Air Cooled Marine Propulsion Engine. Although there are some differences. I have looked at other pics online and it also looks a lot like the Lister TR air cooled (2 cylinder)  So it might not be that one. I was wondering if anyone could tell me how to identify which engine I have?
Also I have been having starter motor problems since I have had the boat (about 18 months) Twice I have had to have the starter taken off and worked on. I realise it would be hard to help me with this problem if the correct engine type isnt known but hopefully once I find that out someone might be able to give me advice about the starter.
I had it reconed in the summer and was hoping that it might be sorted but the boat didnt start yesterday but with a bash to the starter it did so it looks like the starter problems are starting again (or not lol)
Anyway helloand thanks in advance :)
Re: hello
« Reply #1 on: October 16, 2017, 03:43:27 PM »
Hi, and welcome aboard (so to speak)!
The best way to ID your engine is to find the spec plate. The serial number - assuming it's a post 1952 engine - will contain the type. If you can't see/can't get to the spec plate, then the next most likely place for the S/N would be stamped into the outer face of the flywheel - at least, that happened with CS engines, I presume others too).
Can you get photos? Some of the members here have extensive experience with Listers and may well be able to ID it by sight.
Can you describe your starting problems? Is the engine turning over at a decent lick but not firing? Is the starter motor just clicking, or doing nothing at all, or letting the Lucas Magic Smoke(TM) out?
Re: hello
« Reply #2 on: October 16, 2017, 06:52:18 PM »
Hi Debbie,
Welcome.  One photo would speak so many words.
Casey
Debbie
Re: hello
« Reply #3 on: October 17, 2017, 03:53:43 PM »
Hi and thanks for replies. I am away until Thursday but will take some pics when I get back. And check for any numbers too :)
With regard to the starter problems I have been having. It begins by just clicking, not turning over at all. A wee bash with a hammer seems to sort it. (I am pretty sure this isn't good for it.)  This method of getting it to start works a few time but then, unsuprisingly, it doesn't anymore.
For a while I didn't have a float pump in my bilge, so supect that the starter got wet, as it sits quite low, and rain water and canal water from the prop does get into the bilge. After fitting the float pump I thought that problem was rectified.
I am wondering if damp getting itno the engine could be causing corrosion with-in the starter motor? And if that is the case what the solution might be. Canals are pretty damp places. WD40 sprayed onto the starter? covering it with a bag when moored up? Any ideas gratefully recieved :)
Re: hello
« Reply #4 on: October 17, 2017, 04:04:05 PM »
That's the classic symptom of a stuck solenoid. When you press the starter switch, rather than passing the entire starter motor current through the switch (which could be hundreds of amps), instead you turn on a solenoid. This does two things - it connects the starter motor using heavy-duty contacts, and also it throws out the starter pinion which engages in the flywheel. Tapping it with a hammer when it gets sticky is a classic workaround (and you won't do any particular damage to it, so long as you're not smacking the hell out of it...
Solution: Have the solenoid rebuilt. Or get the make/model of starter motor & find a solenoid kit for it & DIY. At a guess, any garage that deals with commercials should be able to handle a solenoid rebuild for that starter motor, or any marine specialist.
Debbie
Re: hello
« Reply #5 on: October 18, 2017, 11:14:11 AM »
Thanks guys. I am not mechanically minded. But I think I understand what you are saying. I definately won't be able to do this myself and so will get it looked into. And yes I will definately take your advice with going to a regular garage/ parts dealer. You are absolutely right prices are definately hiked up if the word "marine" is mentioned.
As this is the 3rd time it has happened in the last 18 months does anyone have any ideas as to why this is a recurring problem? I do suspect when it happened at first it was because I didn't have a float pump and the starter motor got wet, but now I am not sure why it has happened. Any ideas as to how I can stop it happening again?
Re: hello
« Reply #6 on: October 18, 2017, 01:16:47 PM »
Hi Debbie
A bit off topic, but..........
Whatever you do get a bilge pump with an automatic float switch and wire it to the biggest set of batteries on board, don't add a switch or a fuse, it not starting when you desperately need it far outweighs the chances of it catching fire.
For the sake of safety, connect a second float switch to a flashing road works lamp (using the lamps integral battery) on a wire that allows you to hang it where someone in the port / marina / harbour / mate on the barge next door can see it when you're not aboard for long periods. Mount the bilge pump float switch in such a position that the flashing light comes on first, it'll cost less than 50 quid for peace of mind.
When you get next get some one to look at the starter, watch them closely, it's not a difficult thing to understand or repair, check out Youtube for more.
Cheers Stef
Re: hello
« Reply #7 on: October 18, 2017, 08:52:14 PM »
Stef, something tells me there is a story behind that sound advice.
Re: hello
« Reply #8 on: October 18, 2017, 10:04:19 PM »
It's a long one, Tom
It starts in '75 when I was drafted to Poole, Dorset, prior to a, 18 month commission on HMS Fearless (long since melted down for razor blades) working on landing craft, and is still ongoing on a small 'rich man's Med sled' out of Tarragona, in Spain.
In between I've refitted a narrow boat and a Dutch barge for myself and worked on all sorts of small commercial work boats and the like.
Most of it's been done on a shoe string and the commercial one's mostly under pressure to 'catch the next tide'. All of which has led to some monumental cock ups and the ability to sort them quickly or concoct a reasonable excuse for buggering off down the pub!
Joking aside, I picked up the road lamp trick from an old boy in a small marina years back and having knocked up 8 or 10 over the years, I've never had to rely on one, I hope there's never a first time...........
Cheers Stef
