Author Topic: Build date?  (Read 2224 times)
basewindow
Build date?
« on: October 09, 2017, 12:08:50 AM »
Can you tell the build date from this?
Its a Lister CS
On the Brass Plate
No: 676313
Hp:3.5
RPM:650
On the block
20842
9E53
Cam
1953 CS Lister 3.5hp, 1938? Bamford SD1 3.5hp, 1962 Fordson Super Dexta, 1969 International 434.
Re: Build date?
« Reply #1 on: October 10, 2017, 12:22:47 PM »
Hi Cam,
Can't give you a build date, but you can get to the year...
Lister used 3 serial numbering schemes for the CS (and other engines): Plain numbers (usually prefixed "CS") until 1951, a "coded" system from 1952-1970something, then a different coded system.
Yours looks like the middle system, and therefore breaks down as follows:
676 3/1 3
This means it's the 676th 3/1 type engine built in 1953 (the last digit or 2 digits, one adds 1950 to get the build year).
HTH!
basewindow
Re: Build date?
« Reply #2 on: October 11, 2017, 09:52:27 AM »
Thanks for that. I figured it was early 50's. Somewhere i had the idea that they only started producing the 3.5hp around then?
Re: Build date?
« Reply #3 on: October 11, 2017, 09:48:11 PM »
The 3/1 has been around since the early 1930s, only a couple of years after the 5/1. At some point, both engines were "uprated" by increasing the running RPMs from 600 to 650 - giving the 3.5/1 and 6/1 engines that we all know and love. The 8/1 IIRC is the same bore size and stroke as the 6/1 and gains its extra horsepower by running at 800rpm (again, IIRC), the original 9-1 (aka JP1) running at 1000rpm to get 9hp.
If I remember, I'll dig out my Lister CS Story book (the late David Edgington's comprehensive coverage of the development of the CS engine range), that should tell us (at least approximately) when the first "official" 3.5/1 left the factory.
starfire
Re: Build date?
« Reply #4 on: October 11, 2017, 11:06:24 PM »
I vaguely remember the CS was developed by placing the deisel top end on the early petrol base, these then proving unreliable until the crank bigend journal was increased in size to cope with the added stress. Just what allowed the later increase in RPMs I would be interested to find out.... my owners manual suggests contacting Lister if wanting higher operating RPMs. Its not often realised that even small increases in speed raises stresses very quickly, a logarithmic curve. where a doubling in  RPMs quadruples the loading.
Re: Build date?
« Reply #5 on: October 12, 2017, 11:24:00 AM »
The CS crank case is very similar to the Lister "A" petrol engine, which was first developed in the 1900s, however I suspect it was a purpose-built casting from the start.
Re: Build date?
« Reply #6 on: October 12, 2017, 01:12:20 PM »
Actually the original CS types were built on modified model L crankcases.  The 650 RPM engines along with the higher ratings came about early on, I dont remember the exact date but I used to own a 1939 CS that was tagged as 650 RPM and 6 HP.
