Author Topic: that Chinese coupler  (Read 3423 times)
32 coupe
  • "Doc Johnson" on call !
« on: September 30, 2017, 11:30:52 PM »
When I acquired my changfa engine and st head a number of years ago, a direct drive coupler
was available
The said coupler has a series of o rings stacked on a set of pins that act as a bushing in a
matching drilled faceplate.
The original rubber o rings lasted for a time and needed replacement . I fabricated a set of
new ones from a 1/4" rubber sheet I had about and they lasted about 50 hrs or so.
I bought some delrin and am considering cutting some "bushings" from this material.
Any one else use this coupler and have any experience/input ?
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
vdubnut62
Re: that Chinese coupler
« Reply #1 on: October 01, 2017, 05:04:08 AM »
I think MobilBob talked about these several years ago.  I could be completely wrong . Anyway the gist of the conversation was that the Chinese couplers were a pretty short lived solution. a lovejoy is much better.
  I used the coupler from a Mercedes driveshaft, no problems so far!
Ron
32 coupe
« Reply #2 on: October 01, 2017, 05:56:48 PM »
here is a picture to give a better idea
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
« Reply #3 on: October 01, 2017, 08:17:14 PM »
I'd measure ID and OD, and look for some reinforced rubber hose that would fit.
« Reply #4 on: October 05, 2017, 12:48:19 PM »
 I read enough bad prior to building my set that I avoided them and went with belt drive at 1 to 1. Your experience is matching about everyone else's. That being said Chinese rubber is mostly junk in my experience. Were I wanting to repair one I would check Lovejoy's web site and find out what material they use in their severe duty elements  and then check McMaster Carr or Ebay for some stock andmake up a set,, and a set of spares.
I know,not much help,,,
xyzer
« Reply #5 on: October 05, 2017, 04:04:10 PM »
Most couplings life is dependent on alignment, and material quality. They are great because they work for awhile when not aligned. I would spend some time get it aligned the best you can then maybe use some hard plastic tubing or rubber. Cut a set of spares while you're at it.
Dave
Vidhata 6/1 portable
Power Solutions portable 6/1
Z482 KUBOTA
