This morning I was continuing the generator shed tidy up, and noticed a crack where one spoke joins to the center hub. This crack was quite noticeable where it had worked a small ridge in the paint that was applied only a month ago. This spoke has been moving as the engine rotates by the looks.
This is something I guess we should be aware of.
I know cast iron has little expansive strength, and over the huge amount of time, the metal possibly can become brittle. I dont know if cast iron work hardens, but what is concerning is the danger of a flywheel disintegrating and actually killing someone in the vicinity. Its not hard to imagine the mess..... the engine alone is likely to rip itself off any mounting base and wreck itself as well. The spokes are also subject to huge torsional vibration, especially with large singles, and exaggerated by driving a load from the flywheel rim. This could well be why Lister did not put vee grooves into the rim, instead fitting a choice of pulleys direct to the shaft.... here Im just guessing.
Ill get a photo up when my camera charges.
I suggest periodically that all engine owners check their flywheels on a semi regular basis, maybe even tapping with a small hammer listening for a change in sound.....
