Author Topic: in house servicing  (Read 1713 times)
old bob
in house servicing
« on: August 22, 2017, 07:56:27 PM »
My CS which I believe to be a december 1946 model (CS56022) has a brass plate riveted to the rear of the cylinder which states .....the cylinder is 10 thou oversize.... so I assume that at some point the cylinder was removed and sent to lister who did the work and returned it with a new oversize piston, from what I know the engine was probably worked hard for the first twenty years of its life and I know personally that it has not been punished during the last thirty years, anyway has anyone else got a CS that has been returned to lister workshops for servicing/repair that was returned to the owner with a workshop brass plate riveted to the unit
Re: in house servicing
« Reply #1 on: August 22, 2017, 08:46:53 PM »
I have seen the same brass plates affixed to identify machine work done on the bores... no particular identification of who did the work though.
« Reply #2 on: August 22, 2017, 11:08:01 PM »
Mine has the same plate. Bored .010" over and re-chromed. I too assume it was done by Lister. The oversized piston is a Wellworthy brand with the Lister part # on the inside.
« Last Edit: August 22, 2017, 11:10:43 PM by broncodriver99 »
