It's hot..........bloody hot up here in northern California, plus we have massive wildfires burning all around our little city. At 2:45 yesterday the power went kaput and took our evaporative cooler down with it. I called the power company and their estimate was 6:00 pm before restoration, and our house was beginning to get a "little" warm.
I rolled the Listeroid out of its storage hole in the garage, checked various fluids, oiled a couple of things, then cranked it over. It started on the first compression stroke and settled down to its normal working speed. I plugged in the cord, moved the cutout in the breaker box and everything came back to life.
I was later informed that there were 2400 households without power. The only places still operating were the local hospital, city hall..........and George
When the wife got home at 4:00 pm, she walked into a nicely cooled house with the news on the the t.v. I plugged my Kilawatt into an outlet and got a reading of 105 volts, so I shut off the cooler and the voltage jumped up to 117. Hmmm.
A couple of things I noticed and will attend to: the generator body got hot to the touch after about an hour. This was a combination of the ambient air temperature (over 100 degrees) and very poor ventilation. I removed the entire rear shroud during the run and that let a LOT of heat out. I'll perforate that shroud with vent holes before I reinstall it. This generator is military surplus and only 2500 watts, enough to operate the refrigerator, lights and t.v. I also checked the tag on the cooler motor and that bugger pulls 7.4 amps on high speed! Combined with the t.v., fridge and the air temperature, no wonder it got hot! I'll start looking for a 5000 watt unit.
I also noticed that my intake tappet isn't rotating. I can give it a spin while running and it'll rotate perhaps a half turn, then stop so it looks like I'd better pull it and check the cam surface. Probably not finished all that well.
All in all, a successful 4.5 hour run with no major problems and a couple of minor flaws detected. I really LIKE my engine!
