Author Topic: 12/2 clones have arrived...  (Read 7711 times)
Re: 12/2 clones have arrived...
« Reply #15 on: August 10, 2017, 06:40:59 PM »
We also have the COV parts if anyone wants them anymore...   :laugh:
listard-jp2
« Reply #16 on: August 10, 2017, 07:55:29 PM »
In their more modern versions Lister experimented with what they called odd-fire and even-fire arrangements (in 2-cylinder and 4-cylinder engines). This amounts to the same thing described as opposing crank throws vs matched crank throws (split-twins?).
Would this be the sort of LPW2 crankshaft you had in mind, when using the term even fire.
http://www.ebay.com/itm/DN2M-1-Onan-crankshaft-kit-5kw-Military-diesel-engine-LPW2-Lister-Petter-NEW-/291338225300
« Reply #17 on: August 10, 2017, 09:12:59 PM »
Yes, that LPW2 crankshaft has both connecting rod throws on the same side of crankshaft and were identified as "even-fire". Odd-fire would have the throws at 180 degrees from each other.
Bear in mind that I am translating and inferring a bit of this information simply from hands on the parts and from observations made on the actual engines. This is not from any written documentation - that seems to be completely absent from the records we have been able to unearth. We do have 100% of the factory records as far as I know, but sometimes this sort of thing will be in memo format and much like the proverbial needle in the haystack.
« Last Edit: August 10, 2017, 09:22:07 PM by dieselgman »
arboles
« Reply #18 on: August 11, 2017, 12:31:10 AM »
What does this engine cost? Anyone in the south selling them?
« Reply #19 on: August 11, 2017, 02:34:06 AM »
Parts kit for 12/2 offered at $3475 and will ship anywhere needed. 38ac is in Ohio and our main warehouse location is in Kansas.
arboles
« Reply #20 on: August 12, 2017, 05:53:36 PM »
I use to follow these engines on eBay years ago, and was planning on acquiring one for emergency use. Will the kits be available for the forseeable future?
« Reply #21 on: August 13, 2017, 02:55:26 AM »
As far as we can see, no worries about availability of the kits. It is an uncertain world, pricing and delivery costs will vary according to both political and market conditions.
