Author Topic: Oil drain on Liste LD2  (Read 1759 times)
CCOS
« on: June 14, 2017, 04:28:53 AM »
Hi, a little embarrassing but I can't seem to find the oil drain plug on my engine, I can see a bolt on the side of the crankcase but I believe at is the oil filter mess behind that bolt. So where do I look for the drain plug?
Jesper
Re: Oil drain on Liste LD2
« Reply #1 on: June 14, 2017, 02:07:38 PM »
Bottom edge of crankcase, just follow it around until you find the plug. Maybe obscured by dirt and may be slightly recessed.
