Well, I'm glad the information proved useful
I'm pretty sure Lister suggested a humongous block of concrete as a base for the CS engines - I don't think the size varied based on engine HP either, so one assumes it was good for the 8/1, overkill for the 6/1 and total overkill for the 3/1... The purpose of the cast iron (and later fabricated steel) bases was simply to keep engine & alternator in the correct relationship with each other. However, as I say, mine just rested on a pair of 2x2 timbers (not bolted to them, nor were the timbers bolted to the floor. Sure, eventually it might fall off them, if left to its own devices... I never ran the engine long enough for that to happen (max of 1hr runs, I could easily get my coolant tank - an insulated domestic copper hot water tank - up to 50c in that time). In truth I haven't done much Listerish for the last couple of years - lack of time, motivation and now location... But now I fancy a play with it again (typical!), back in the UK in just over a week, so I'll start making some space in the shop for a dicker around with it...
Would this be Chinese or jail back home? :0)
Welll...... as far as I know, there's no extradition treaty between China and the UK... I should be able to get a residency visa for China easily enough..... so if the UK start getting a bit frisky, I'll transfer the house into the old man's name, and get my arse back over here ASAP
I feel your pain with the stamp duty, we have the same nonsense here (UK), although ours isn't quite as vicious as yours by the sounds of it.
I think there is a buck for you to be made in distribution of China engines Ade. Might have to pull the injection pump, tank and injector and call them compressors for the US market but plenty of other places in the world you could sell them as well.
I'm planning to do a bit of research in the UK to see if there's much demand for them. If there seems to be, then I'll definitely look at bringing a 20ft container load across (I think I can fit 100 units in, call it 80 plus a few boxes of spares), thats all 12hp, I guess there may be call for a few different sizes, I think the water cooled singles are available in anything from 5hp to about 30hp.
I'm watching what Trump does/doesn't do with/to the EPA with some interest... but TBH that's probably better handled by someone Stateside. I suspect the demand is greater over there too... and (EPA aside) the rules are less draconian than here in the EUSSR (as it's unkindly called by some). One of the things I'll have to do, certainly if I want to sell them across the EU, is get CE certification. The factory tell me this will cost around US$1200, whether that's actual usable documentation, or just a phoney certificate they download off the 'net, tweak to have their name on, and hand over... well, I don't know.
Finding myself in need of a ride on mower now, I'd love to find a suitable Vertical shaft Diesel that I could use as a replacement motor for a ride on.
Something 20 HP and up would be fine as a lot of the mowers run twin Cyl 23-27 HP petrol's now. There would be a good market for those in OZ alone I reckon and if you could find a 5HP that went on a push mower in a Briggs/ Honda pattern..... I'll take the first container load.
I haven't found any vertical shaft water-cooled diesels at all... Do the petrol engines run with a vertical shaft? Or do they have a right-angle gearbox? I'd be more tempted to run with that; or maybe a twisted belt drive?
The only other option would be to fabricate a dry sump and run the engine on its side. Actually, I can't see any real problem with that, except the flywheel would have an interesting gyrosope effect... you might only be able to mow your lawn clockwise!
I'd also suggest you found a Chinese Foundary to make Roid flywheels but I seem to recall that there is no standard setup on those either so you'd not know what weight to set them up in the first place. Maybe include a set of stick on wheel weights with each pair? :0)
Hmm, I don't think I'm going there...! There's not much (if any) of a 'roid market in the UK (too many originals), and none in China (they've got the horizontals that we also crave after)... Nah, I'll leave that to someone Stateside
