Author Topic: Fuel Filters Suppliers  (Read 5618 times)
Listerational
« on: November 13, 2016, 09:42:56 PM »
Greetings,
Can someone please recommend a good source for fuel filters? I have a Powerline 10/1.
Thank you,
JB
Re: Fuel Filters Suppliers
« Reply #1 on: November 14, 2016, 12:50:13 AM »
What type of filter does your machine have? Early style OEM filters were of the "rope" type, and later ones switched to a small paper filter. We stock OEM parts.
The Indians have swapped around several variations of their own.
Listerational
« Reply #2 on: November 14, 2016, 12:58:32 AM »
Hello Diesel,
This is the paper type part number H08R12B1.
Thanks,
« Reply #3 on: November 14, 2016, 01:39:10 PM »
All of the Powerline engines I have been around have a filter like the one pictured?  I have not found a suitable element anywhere except through Powerline or one of their dealers. The way the head is made makes it near impossible to adapt a similar filter.  Here in the states the dealer I use for Powerline specific parts is Central Main Diesel.  Most of those filter heads get switched out.
« Reply #4 on: November 14, 2016, 02:13:07 PM »
CMD then is the best choice to use for that style of odd Powerline housing. If you ever need the AC Lister OEM style, we have excellent stocks here.
Listerational
« Reply #5 on: November 15, 2016, 01:34:26 AM »
Thanks for the help sirs. I emailed CMD for info on the filter.
« Reply #6 on: November 15, 2016, 02:22:59 AM »
The late Lister CS OEM filters (made by AC) look exactly like the one hanging off the side of this newer Alpha:
We have plenty of this style available - both the filter assemblies and the filter elements that go inside.
« Last Edit: November 15, 2016, 02:23:21 PM by dieselgman »
« Reply #7 on: November 15, 2016, 11:38:05 AM »
My experiance with CMD is your better call. They have yet to ever answer an email.
vdubnut62
« Reply #8 on: November 15, 2016, 06:35:40 PM »
Glort, here in the Land of the Free and the Home of the Offended, The Powers that Be don't let us have cool small fuel efficient diesels. Well, maybe a VW or two.  Sure I have a Big honking Six Cylinder 5.9 liter diesel pickup that plastic and paper cartridge type fuel filters cost $30 US each, but I don't think I have ever seen a Diesel Suby.  I gathered up a couple 1.5 liter VW fuel filter bases for my projects. They use a spin on filter and cost $8-10 bucks.
Ron.
George A
« Reply #9 on: November 16, 2016, 11:50:21 PM »
My Vidhata wouldn't start for sour apples after I foolishly installed an inline (hose barb) style filter. I timed it and cranked it until I turned blue. Nothing, even though I could see fuel in the transparent filter. After letting it sit, unloved, for almost six months I decided to bypass the filter with a straight line connection and it instantly fired up. The problem? An air bubble that was plainly visible and "shouldn't" have caused a problem......but it did.
I then followed the lead of someone (on this forum I believe) by tapping the OEM filter inlet (in the top) to 1/2x20 tpi so it now accepts a Fleetguard FF5044 filter INSIDE the original housing. Changing is just a matter of removing the bowl, unscrewing the old filter and screwing in the new one. Reassemble the housing and you're done.
