Hi Mike
Should you ever find any difference between the 3/1 and 6/1 flywheels, please would you post it up.
I've just rebuilt a Bitza into a 6/l on what I believe is a 3/1 bottom end, I've swapped the piston from iron to aluminium and this has moved the 'critical point' vibration from around 450 rpm to 660 rpm, thus making it a useful 6/1. I lack the balls to try and rev it to 800.....
As with all projects I've only spent far too much on it and have loads of bits left for the next one, it would be good to know if there is a difference before parting with more cash in the wrong direction!
Cheers Stef
