Hi
As mentioned, check the crank first, if it's as far out as 6mm you should be able to see the problem using a nothing more than a pair of axle stands.
The doorway press works, I do it horizontally between the posts of my stone built barn as the roof is relatively light.
I've recently replaced the mains on my 6/1 with roller bearings from Devprecision, in Rajkot, India. the bearing carriers were poorly machined and lacking a lathe I set about things with a 4" angle grinder and 'adjusted' the bearing cases to fit. The worst bit was the lack of allowance on the inner races for the radius on the crank webs. Do remember to clean all the grinding dust out of the bearings if you try this at home!
It took an afternoon, a lot of test fitting and a set of gaskets made from a Lidl's beer box and printer paper to centre the crank.
If you go down the Dev route make sure you order the taper roller bearings for 2" shaft, I ended up with 2 1/4", after a bit of prompting they were replaced FOC.
There's a lot of good, helpful guys on the site with loads of knowledge and real time experience working out of workshops you could dine in, there's also a contingent working to minimal budgets with little more than hand tools. Never loose sight of the fact that the CS roots are around a century old and blokes with nothing more than a few spanners and a lot of 'common dog' have been keeping them running in the back of beyond ever since..........
Cheers Stef
