Author Topic: DES 8/1 generator build  (Read 40706 times)
Re: DES 8/1 generator build
« Reply #15 on: October 15, 2016, 07:51:06 AM »
I hope that all-thread won't break sideways through the pour, did you use any reinforcing fiber in the mix or anything to strengthen the concrete ?
gusbratz
« Reply #16 on: October 15, 2016, 01:11:31 PM »
nope no fiber, just extra portland. I am very confident my 2'x3' lump of concrete will be up to the job.
32 coupe
  • "Doc Johnson" on call !
« Reply #17 on: October 15, 2016, 02:56:29 PM »
I will be watching this to see the results.
I am a firm believer in the fiber reinforced concrete.
Those Lister clones will pound the crap out of anything they touch.
I have 2 of them and have spent hours getting them to run smoothly. The single cylinder is
much worse than the twin.
Keep us updated !
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
32 coupe
« Reply #18 on: October 15, 2016, 02:59:19 PM »
Oh, did you get the brass/bronze idler gear ?
I will be more than happy to provide you with an offset idler bolt if needed.
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
gusbratz
« Reply #19 on: October 15, 2016, 05:13:10 PM »
the engine came with a cast iron gear. DES provided a  full set of spare parts and that gear was also cast. i wish i had the bronze one but i think i will put some hours on what i have before i dump any more money into parts. this could easily turn into a rabbit hole. i think as long as i inspect the gear condition during oil change time i will be able to see if it's wearing funny. maybe i will do a prussion blue gear mesh check before i run it just to see if everything seems lined up.
« Reply #20 on: October 15, 2016, 05:49:20 PM »
Dave, aka xyzer, sorted the idler gear failure issue many years ago.  His findings: The idler is mislocated in the block, causing way to much play in the gears, and the amount of error is typical Rajkot- all over the map.  Dave made several batches of offset idler bolts of various offsets and sold them to fellow CS enthusiasts. I have one in my diesel 6/1.
With some piano wire and a dial gauge it's possible to measure the lash.  You will typically find either crank or cam with have huge amount like 0.030 inches instead of the 0.006 you'd like to see.  With an offset idler bolt you can fix  the tolerance problem.
We used one of 32coupe's offset idler on the DES 8/1 propane conversion engine and I thank him again for his generosity.  They work great for moderate errors. It's a bolt with an offset sleeve.
gusbratz
« Reply #21 on: October 15, 2016, 07:42:42 PM »
ok, I will keep that in mind that I am looking for around .006 backlash when I get to putting it back together. how hard to balance are they? or check the balance? I mean I understand a big one lung engine is always going to thump some but shouldn't it be fairly smooth.
gusbratz
« Reply #22 on: October 15, 2016, 09:11:27 PM »
I am also looking for some clearance's . I have heard a few thrown around about striking clearance (.45 for my 8/1 from my manual that came with it in the crate)  and crank pin clearance (.0015-.003 from here on this forum) but am looing for the thrust clearance between the crank and the main bushings. I see that the Indians had a small piece of gasket under the top of one bushing carrier to shim the top out away from the main frame. as well as multiple gaskets stacked on every thing on the whole engine.  I have forgotten the thumb rules in the manuals I used to have access to when I serviced IR gas line compressors but I thought it was .001" per inch of shaft diameter. I also worked on AJAX engines and they had all splash lube oil systems. from rebuilding many engines I learned that more stuff got trashed with tight clearance than loose so I always erred on the loose side on the engines I worked on.  piston ring end gaps close up as rings heat up and scuff cyl walls, rods and pistons expand out and close up striking clearnces as they heat up ect ect....
32 coupe
« Reply #23 on: October 15, 2016, 09:57:32 PM »
I don't have the clearances handy but will look for them if someone doesn't chime in.
The idler gear setup.....what I found was the gears (crank, idler, cam) are not round. The clearances will change
as the crank turns because the gears are slightly egg shaped. Setup requires some "feel" for the clearance with
a happy medium for the final set.
The offset idler bolt is your best bet.
The side plates holding the crank bearings will be the same thing. Gaskets will be stacked up on both sides
to achieve the proper side clearance. I don't  remember the desired clearance but it is also necessary to get
the crank centered in the block during the process.
The bearing holders are so large that you will see that as you tighten them down things will change.
My twin has brushed bearings instead of rollers. I had to get the side thrust close then tighten the bearing holders
gradually as I turned the crank for the best clearance. As I tightened the holders I could feel the drag on.the bearing/bushing and ended up with the least drag/best feel. Rollers will be a little more forgiving.
I made a stack of side Gaskets then soaked them in oil before installing them. Several thicknesses are necessary.
File folder paper and note book paper and brown paper bags make great gasket material . It will take several attempts to get it correct. I used a magnetic dial indicator for.the final adjustment.
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
32 coupe
« Reply #24 on: October 15, 2016, 10:35:35 PM »
I wanted to add If I remember correctly I spent about a day just setting the crank.
I am the slow and cautious type so I'm sure someone here could do it in an hour or so.
These beasts are just 3rd world junk as compared to the real thing being Genuine Lister.
I have NO experience with real Lister's and in fact have never even seen one that I recall.
The Indian stuff makes a great toy and many here have had great success. Many failures
have been noted as well. Some catastrophic failures will arise with even the best builders/assemblers.
At 62 with a day or 2 of engine work for more years than I care to remember, again I think the
clones are at best a great toy. I just wouldn't want to have to rely on them.
Any engine will be a crap shoot. Some live some don't.  Proper setup with close tolerances are all one can
hope for. These engines are just so plagued with problems that the probably of having problems with them
is almost guaranteed at some point.
I will add that setting the crank can be very rewarding. When you get it installed and the clearances are
correct turning that monster by hand and feeling the crank "float" is a great feeling. The downside is that every
single stage of assembly has to be done in this fashion. You cant trust any of the clearances to be correct.
Every surface has to be checked for parallel /square. Some have noted 1/2 gaskets on side plates and the same
at the bottom of the jug to get things to line up.
Patience and thinking will be your best friend.....
After rambling on, I will amble off.....
« Last Edit: October 15, 2016, 10:53:05 PM by 32 coupe »
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
gusbratz
« Reply #25 on: October 15, 2016, 10:40:55 PM »
I am hopeing to make my clone as good as an original lister. trying to think of it as a 90% finished kit engine. I  guess I underestimated how far from the real thing they are.......
« Last Edit: October 15, 2016, 10:43:08 PM by gusbratz »
« Reply #26 on: October 16, 2016, 03:36:36 AM »
There is a wide range of experiences with these... don't be dissuaded by the few disasters. We tend to hear a lot less about the success stories, but those ARE the majority for certain.
crankshaft end float should be around .005" to .010"
cylinder head clearance (bump) height should be .075" to .080" for your 8/1
« Reply #27 on: October 16, 2016, 05:37:48 AM »
+1  The important thing is to go through everything carefully. 38ac's engine build piece is fantastic. My older Metro 6/1 is pushing 3000 hrs this year.  I had issues only because I didn't do the complete rebuild up front. I had sand filled grease under the piston crown, and a cylinder liner that projected too much and thus head gaskets failed regularly, and a crooked connecting rod.  Those who just clean the sump and run them are the ones who may have some surprises, not likely with a serious build.  It's just SO much easier to go over everything ONCE, before you put it in service, that I highly recommend that approach.
32 coupe
« Reply #28 on: October 16, 2016, 01:12:03 PM »
Don't let me discourage you.
Gary's engines have a reputation for being better units than most.
He also has an excellent track record of standing behind his products.
The thing is to be careful with every step during assembly. And more
importantly is to have fun with it !
Everyone here will be more than happy to give guidance and help in any way we can.
The offset bolt I offered will definitely help with gear adjustment. I have given several away so
it's not like I'm trying to make money from them. If you have a lathe they are easy to make and
we can guide you through the process if you have questions.
Have fun with it. When you see/hear that thing fire up it makes all the stress/worry melt away !!
Gary
Ashwamegh 2/25
John Deere 110 TBL
New Holland TC 30
gusbratz
« Reply #29 on: October 16, 2016, 03:40:27 PM »
I am making some very good progress and enjoying myself. I spent about 4 hours over the past few days with the harbor freight mini needle scaler and it worked fantastic! i was able to get to all spots inside the case. That was good advice and i sure am glad i did it. There was some low hanging fruit like corners of the gov recess ect where you could see pockets of sand but there were also some real surprises. as i needle gun'd along the bottom there were places that looked good and the white paint would blow away and i would get into 1/8" of mill scale or sand or whatever the black dust is. hard to imagine that you would run a factory putting engines together, casting parts and finish machining them with no plan to clean them before assembly. they sloped a light coat of white primer or something in there so on some level they were trying. i draw filed all the machined surfaces and wire wheeled them then wiped the frame out with solvent. i have chosen not to paint the inside red since it has been exposed to oil and i feel the risk of paint flaking off and gumming up the works is higher than the reward of having red paint.
    Then last night I  cleaned assembled the crankshaft support bushing houseings. again they looked fine but when the nedlle scaler went across them sand and scale just flowed off them. I then held an 18" starret level up against the vertical part of the frame where the bearings bolt and laid a starret square on the top and only a tiny bit of  light was visible so i am calling that square enough. I assembled the main bushing hoseings metal to metal without the crank. tightened  them up then took a set of inside mics and measured the top bottom front and back clearince between the bushing thrust surfaces. bushings were about .003 tighter at top than bottom. measured crank  with a big set of 6-9" mics at work and they show that the gear is not on quite square, off again by about. .003 from top to bottom. did the math for my shims and came up with .122 difference. divided by 2 is .061. the indians had .060 of gaskets on both sides with a .004 shim on the top. the measurements show how the bushings were closer on top than bottom so somebody over there was on the ball and aware of the issue. I made new gaskets out of 1/16" garlock (.062") then assembled the whole assembly with crank this time and it would bind a little bit as a rotated the crank through the top, even though feeler gauges showed .004 clearance all the way around. I made one more paper shim out of .005 and installed it and now it spins real nice. falls right to the bottom under it's own weight so I called the crank good to go with .010 of thrust clearance as measured with feeler gauges.
    This morning i put the idler gear in and temporarly installed the cam since you got me worried about them now. at a glance i would be totally happy with that backlash. i have been into tractor transmissions that had gears this size to move the whole machine with  way more backlash than this. I ran a piece of lead solder through the idler and crank gears and get bits of lead .008-.010 thick. then ran a bit of lead solder through the idler to cam gear and got .010-.018 thick. i can't imagine taking the time to build an offset bolt to close it up .006 would make the difference of a tinkers ass in hell. If those gears are junk they are junk. I did have a bit of white paint on one of the gears from when i took it out. i reached in with the wire wheel to clean it off and you could clearly see the marks from the wire wheel in the gear tooth i touched so they are super soft, usually a file will just skate off a gear tooth. so i guess i will just run it for a while and if they look like they are wearing i will make myself a whole set of gears from scratch. I have the tooling and have always wanted to make a gear. I know you can buy gear blanks to machine your self. here is the project as it sits now after a lot of cleaning.
