Author Topic: What is the max rpm for a Lister SR1 - received and answer from another thread  (Read 2268 times)
vanair
Hi
I am from South Africa and are busy restoring a SR1 and also want to power a 2.6 kva alternator that needs to run at 3000 rpm.
What is the maximum rpm a SR1 can be run at?
I have searched and saw some reference to 2500 rpm but then would have to run a smaller pulley on the alternator.
Thanks
Pieter
« Last Edit: September 13, 2016, 09:01:26 AM by vanair »
Re: What is the max rpm for a Lister SR1
« Reply #1 on: September 13, 2016, 09:01:30 AM »
Please refer to my other reply to your question about pulleys. The SR can be run up to 2500rpm but will be a much nicer machine when run at around 1500rpm. The power output will still be in a very efficient and useable range at the lower speed and most genset builds use the lower speed with a 4-pole head to achieve 50Hz, direct-drive.
vanair
Thanks Dieselgman!
Just modified my topic.
