Author Topic: Lister ST2 stub shaft  (Read 7680 times)
phelan58
« on: September 06, 2016, 07:25:25 PM »
I'm in need a stub shaft for my Lister ST2.
If I had my choice of would be 1.88 inches.
My plan is to power a LIMA MAC 7.5KW generator head, The shaft on it measures 1.874 inches.
I'm still trying to decide if I should drive it directly or use belts.
Any advice would be nice.
Dave
Re: Lister ST2 stub shaft
« Reply #1 on: September 06, 2016, 09:34:44 PM »
Is your LIMA a 2-bearing or single-bearing unit?
The Lister ST will accept SAE standardized housing adapters and drive hubs. These may be used to close-couple the pair and yields a very rigid and reliable machine assembly. This is generally only compatible with single-bearing generator heads.
If you want to use a flexible coupling and a rigid base to align and secure both the engine and generator head, then a simple shaft and lovejoy-type coupling can be used.
belt-drive always will entail extra maintenance as well as a bit of friction losses in the belts and pulleys.
The parts are fairly readily available as there were many thousands of these produced and used throughout the world.
phelan58
« Reply #2 on: September 06, 2016, 10:08:01 PM »
It is a 2 bearing.
