Author Topic: Why have they fell out of favor??  (Read 25359 times)
slimchance
Re: Why have they fell out of favor??
« Reply #15 on: June 26, 2017, 04:37:45 PM »
How do I find you to discuss purchase? For shipping cost reasons, what part of the world are You In?
« Reply #16 on: June 27, 2017, 03:03:01 AM »
I bought one last week. An electric start 8HP.
This engine has turned out to be very good and quite different to my others of the same heritage.
It runs much smoother and quieter and vibrates a lot less as well.  It's quite a nice little engine and I like the electric start on the thing as well.
There seems to be quite a difference between brands and Builds. Not even sure what make this one is branded but it's the pick of the crop of the red Yanmar clones I have that's for sure.
DirtMerchant
« Reply #17 on: December 04, 2018, 02:53:19 PM »
I have a Changlian zs1130 30hp (video here : https://www.youtube.com/watch?v=-R31ZxpoJZg )
 and a Yanmar TF70 7hp that I would part with....or trade for a Listeroid
 I can be reached at dan at hurdfarms.com
Tanman
« Reply #18 on: January 21, 2019, 08:18:28 PM »
buickanddeere,
There are still a few of us young bucks around! I'm 25 and have been tinkering and building as long as I remember (because of my dad and his dad both being teachers in rural MN you fixed it yourself or it didn't get fixed!). I'm looking for an affordable small Diesel engine to tinker with. I have a Subaru Robin RGD5000H I decided is not what I need anymore (trying to sell it), I want something with a flywheel and water cooled. It just seems very difficult to procure a slow speed liquid cooled diesel these days. I found 1 listeroid for sale in a neighboring state with a gen head but they want $3000 and I will most likely have to rebuild the entire thing to make it reliable (half the fun I know, but It would be a lot more fun for $1800 or less). I'm open to the Chinese models as well but I have never seen one for sale in my area.
Hatz 1B40
Chinese 1115
96 Suburban 6.5 turbo
« Reply #19 on: January 26, 2019, 02:31:48 AM »
Now the men at that nostalgic  stage and tinkering with stuff are far and few between. The last  few generations being raised in town by single Mothers has wiped out whole generations of future mechanical hobbiests , fisherman, hunters etc.
Yep. Not only that but the ones who do work on equipment have become "replacement artists".
Don't repair or rebuild it ... just replace it.
To some extent you can't blame them because the replacement parts can be very inexpensive vs the time and effort to remanufacture your own. But having the skill to machine, repair, modify, and problem solve is a very useful skill.
- Kubota Z482 - 4kw
« Reply #20 on: January 26, 2019, 08:16:58 AM »
Good point - Time -
Mine seems to roar away, and I'm semi retired!
« Reply #21 on: January 26, 2019, 12:14:10 PM »
Reliability is everything, is it quicker and cheaper to have a spare everything to hand in the event of a breakdown?
I don`t know the answer to that question, it might be cheaper to buy two identical generators, when you only need one. That way you will always have a backup for your backup. When they are both busted you can probably scavenge the parts to get one going.
Personally, I think it is better to spend your money on quality old equipment and restore it. Old Lister engines, with a bit of work, will probably outlast and out perform modern Chinese or Indian sh1t by decades.
« Reply #22 on: January 26, 2019, 08:48:05 PM »
I worked on maintenance for a short while in an animal feed mill in Blandford, Dorset, that was flat out 24/7 from the first frost of winter to half past April.
Everything ran until it stopped or broke, then you fixed it with one of the numerous back up spares.
One night I ended welding up the discharge chute on 'pony nuts'which had worn through on a sharp bend, the foreman wouldn't stop the line so I wedged a sheet of 10 gauge - around 2mm - steel across the whole width  of the chute and set to. after a couple of tacks the molasses coating the inside started to burn, I stopped and the the foreman said 'Keep going Stef, the next batch thro' will damp it down'.
The whole room filled with smoke but as he said, every couple of minutes a ton or so of pony nuts hurtling past kept the chute cool.
The whole system was known as  'Breakdown Maintenance', as opposed to 'Prophylactic Maintainance'. It's not stupid as it would seem, instead of changing out a motor with a 500 hour scheduled working life, for rebuild, the same motor might well run for 2000 hours and then be total scrap. However the cost per hour run would be comparable.
« Reply #23 on: January 26, 2019, 09:09:40 PM »
Breakdown maintenance is the lowest form, practiced by most private companies (like power co.s) trying to maximize profits. It eliminates the need for good management and minimizes parts replacements.  Another good reason to be your own power co., if you have the aptitude.
« Reply #24 on: January 26, 2019, 11:49:51 PM »
Hi Stef, we used to be expected to do similar sorts of things in the saw mills. Welding in an environment that is laden with sawdust is very challenging and we always had a fire spotter with a fire hose stood beside us. Got soaked a couple of times when things got away from us.  :laugh:
